Yeah, thanks Stevo. That Route looks good.
I'll try to do a google map, directions and some research on a good lunch snack in Albury. I'm a morning person so suits me just fine - as long as I have my coffee.
Anybody else interested in getting a decent CB radio so we can chit chat on the way?
  • Replies 551
Posted Images
Yeah I'd be keen. $$??
You get to sleep in :P.
Nah nothing on Friday thats super special. But getting down there at 6 PM when everyone is getting ready for dinner and us clowns have to unpack cars would suck!
yeah exactly!
PLenty of time to unpack, get ready for Winton the next day and relax with a few bruski's before dinner!
Which Quest?
Fap Quest or Pedo Quest?
No Fapping for me... :whistling:
I can make it on 1 stop so I am fine.
I think what Steveo suggested is the best bet.
Leave PH servo at about 630, Yass to
Pick up the Canberra crew then Albury for a quick stop.
I'll just do a quick fuel dash at every stop we have!
You're on E85? How do you propose to do fuel stops?
I have no idea drew, richard (Sinista32) booked a couple of apartments at quest somewhere... I'll find out where exactly :)
Also I went from canberra to albury and back on e85 with 2*20L jerry cans... How many are you taking?
You going to have the CDI on before the mats Eric?
Yup, Ran all day at Texi ok then on the way to dinner my spark issue returned and has been there ever since. So CDI to obliterate all spark issues! Hope it's ready for the Drag Day.
Here is the CB I'm looking at. It's a 2W unit so should be 4x more powerful than my .5 W POS. They sell a twin set for $250 or a Single for $150.
Twin Set
Single Set
If you are ok with it then I'll go pick up a twin set. You can have the battery charger/doc cause I have lots of battery chargers.
I think 15 should do it.... I'm not joking..
We took 11 last time for DECA. We ducked into Melbourne to fill up 5 empties. I had about 3 full ones by the time I got home.
Ontop of that, this is a trackday! I'm going to watch the needle fall!
Even with how the lagwagon goes, there wasnt NEARLY as much WOT at Deca as there is at Winton.
Your thing sucks as hard as a hooker trying to pay the rent.
Just get a tanker.
Ethanol sensor would be the go. Hopefully that could be in and working by then.
On the freeway though I think a fair bit can be saved (when the 5's go on) for the simple reason that it wont be choofing.... choofing = AFM have a brain fart which = mega squirt from injectors.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
