Picked up new batch today.
Only change is the outer hole slots have been extended to suit GTT. Note: for the GTT it wont sit flat on the floor like it does in other Skylines but is still solid.
pic of the current version below
Just got mine.
The new batch fits perfect, but due to size of my extinguisher, it was in the way of sliding the chair fully forward. I slightly modified it (I bashed it with a mallet) to make it sit lower and it cleared my seat without a problem.
The bracket itself
I flattend it a bit to clear my seat rails
The bracket with my extinguisher bracket installed
Secured on by hex nuts
Complete installation
Nice work Ricky ^ :thumbsup:
Note to other readers this mod to the bracket is not required on any other skylines or Silvias only on R34 GT and GTT because they have a different floor pan.
If there was say 10 x R34 GT or GTT owners who wanted brackets I could get a special batch done without that bend that Ricky flattened?
Group buy time?
  • 3 weeks later...
seat bolt holes are slotted so max 461mm min 421mm center to center, max bolt dia 12mm. inner bolt is approx 20mm higher than the outer.
Pics in this thread will give you a good idea how it goes together.
  • 4 weeks later...
I'm very happy with how this went into my S15.
Thanks Joe.
Have you guys gone over or under your seat rails with it - does it matter either way?
Hi Tinto, looks like you have heaps of room there. pretty serious seat + 5 pt harness btw :woot:
whether it goes over or under depends on how the seat seat rails are formed at the bolt holes. They tend to have a formed lip either up or down. My car has them down so bracket goes on top but whatever works for your car is okay. main thing is that the seat bolts can still get plenty of thread engadged and you can get them nice and tight. minimum 3-4 full turns of thread should be okay. other wise you may need to get longer bolts. also bolts need flanged heads or use a washer.
Okay I may have left this to the last minute but I need on for sau nats.. are there any available? Or is there any where that I can buy one?
I'm out but Chris at racepace may still have one: (03) 9762-9421
i could really do with one of these.....
Joe do u have anymore?
just waiting on a new batch, should get them this week.
also got a few R34 GTT specials made....(thanx to extrq for the R&D, theres one headed your way buddy)
I know some after market seats have levers etc at the front which may be an issue.
:( i'm running Bride Cuga's and my lovely bracket won't fit anymore due to the lever at the front of the seat controller front/back movement.
Not sure if this will be an issue for any Bride rail setup
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
