I am dismantling my R33 GTR and selling everything. As i have a wedding and a house to pay for. Some of the parts are brand new still have been installed but never used, and majority of the other parts have done about 5000-10000kms on them. All these parts are genuine, no fake bullshit here and i don't not have time for time wasters or dreamers otherwise you will be getting told to F#*k off real quick. Here's a quick list for the moment as i would take me days to write out i you wanna see pics just click on the link on my Sig to see everything.
2002 R34 N1 Nur Crate Engine has done 25,000kms since new (done 10,000kms standard setup and 15,000kms with aftermarket parts fitted) and has the following goodies:
- Ross Tuffbond Metal Jacket Harmonic Balancer
-Hi Octane Extended Sump
-Tomei Timing Belt
-Tomei Adjustable Cam Gears
-Tomei 260 Degree x 9.15mm Lift Cams
-Mines Cam Cover Baffles
-Spool Head Oil Drain Kit
P.S this is just the engine for sale no intake or exhaust comes with it.
Asking $10,000
- Series 3 R33 GTR Xenon Lights (Used slightly look new still)
Asking $1900
-Genuine Abflug Carbon Rear Diffuser
Asking $800
-R33 GTR Spoiler with Nismo Carbon End Caps and Genuine Autoselect Carbon Devil Chibi Wing Blade
Asking $800
-Apexi Power FC DJetro with Hand Controller and FC Datalogit Tuning Gear
Asking $1200
-4 Hankook Ventus RS-3 Tire 285/35R18 (Brand New)
Asking $1500
-ARC Airbox and Full HKS Piping Kit Intake (Good Condition)
Asking $1500
-Gram Lights 57F Pro Titanium Lip Rims 18x10 +20 with Tires (In Very Good Condition)
Asking $3000.
-Sunline Racing GT Spec Titanium Front Pipe (Brand New Never Used)
Asking-$1400
-Fujimura Auto Rocker Dancer Titanium Strut Brace (Brand New Never Used)
Asking $900
-Cusco Tension Rod Bar (Brand New Never Been Used)
Asking $90
That's is all for now but visit my tread http://www.skylinesaustralia.com/forums/topic/280567-nur33-soon-to-be-a-time-attack-weapon/ and if there is anything you want just message me.
Cheers
Benny
https://www.sau.com.au/forums/topic/376460-dismantling-my-r33-gtr/
  • Replies 50
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
