It's with great pleasure the exec team announces track day number 4 for SAU:SA at Mallala on the 7th of November!!!
Having been such a great even in the past with both behaviour and turnout, we want the trend to continue so please if you're coming be mindful of track ettiquite and no sliding as per the rules for a grip practice day. As always, there will be 22 spots up for grabs for the first two weeks. These spots will remain exclusive to SA members. If the spots don't get filled in two weeks, it opens up to everyone :) There's two months to the day to get your car ready and time booked off from work so no excuses not to come :P
The total cost for the day will be $200 PLUS an extra $25 if you don't have a CAMS license because you WILL need one ($25 payable to Malalla Motorsport Park on the day). Application is available on the day so there's no worries there, just make sure you have the green stuff in hand. Deposits will be needed as we need to secure the track, this will be half of the full amount (so $100) and will need to be payable by Septmeber 28th, as usual any problems with money and get in touch with us, we aren't monsters and understand things come up so we can work around it. The remainder is due on October 28th so you've got plenty of time to get the cash together.
Lap timers are once again avaliable to be hired from SAU-SA on the day and at a very low cost of $50 per person. These are a great tool to help you learn what works and what doesn't on track and just how things influence your times. They're also good for bragging to friends :P Please note if you want to hire one and we will mark you down on the list. Payment for these is also due on the 28th of September.
Attendees
1. fake400r Full Payment Received
2. Subliminal Full Payment Received
3. ISC-Performance Full Payment Received
4. Normsta + timer Timer & Full Payment Received
5. Jap_Star Full Payment Received
6. ON EDGE Full Payment Received
7. andz Full Payment Received
8. Krishy + timer Timer & Full Payment Received
9. 1gtr Full Payment Received
10. Brezza + timer Timer & Full Payment Received
11. SHIRUBA_XXXIII Full Payment Received
12. Munro Full Payment Received
13. Munro - Radical Full Payment Received
14. bigkevracer Full Payment Received
15. 180or200 + timer Timer & Full Payment Received
16. Spark911 Deposit Received
17. wytnte Deposit Received
18.
19.
20.
21.
22.
Reserves
pistol-pete
Withdrawn
Nonie_13 + timer Timer & Full Payment Received
Rad32 Deposit Received
Damo_R34 + timer Deposit & Timer Payment Received
https://www.sau.com.au/forums/topic/376515-sau-sa-track-day-4/
  • Replies 412
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
