Hi Guys,
I have query about the 3076 that I was sent. I am certain that I requested one with the usual 4inch anti surge, 6 fin compressor wheel with the .60 A/R housing, however I was sent the one in the image below.
It has the 7 fin inlet wheel (T04 wheel I think?) and .70 A/R compressor housing with a 4" inlet.
The exhaust housing is spot on and is the usual .82 that most of you guys seem to use.
My question is if I decided to use this turbo how much worse off would the response be compared to the newer style 3076 with the 4" anti surge and 6 fin wheel?
Is anyone running one like this and what sort of power do you make?
Couldn't find any info in other threads regarding how much power people are making with this turbo with this front housing.
Cheers
https://www.sau.com.au/forums/topic/376583-gt3076-query/
  • Replies 41
that will still make very similar power to the other version, there isnt much difference in them power wise
Thanks Titan.
What about response wise is there much difference?
Another thing will this turbo fit ok between the standard manifold and wheel arch / tower. I have the 10mm spacer. Reason I ask is because of the size difference in the A/R compressor housing size and it looks like It might cut it close..
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6006186
Personally I would return that 7 blade version and get the proper 6 blade version with the 4" ported comp cover...thats what you ordered and thats what you should get...there is some material on here about how the 7 blade versions are inferior...discopotatoe is the guy to speak to...hopefully he'll chime in...
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6006273
Titan is 100% wrong.
I had one, and it made 240rwkw. Maxed. Mater meth, and it made 250rwkw.
Then I got a real gt3076r, 6 blades, surge slots, etc, made 300rwkw. Attached water meth and made 320rwkw.
All on a 0.63 rear housing. Full boost by 3200rpm in 4th. Made 720nm and held that to the limiter.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6006411
Ye the 7-blade one is not the one you want. Bad and nasty performance for what should be the same price for a proper 6-blade.
I actually thought they'd stopped making them in that option given the choices of 3076s out now with various trims etc.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6006438
Thanks for the replys guys.
I have contacted them asking to change it to the correct .60 A/R housing. Will have to wait and see what happens.
Dude, you want a whole new turbo with the 6 blades. Not just the cover.
Ask them for the GT3037. Or CHRA 700177-5007
It looks like the one in my avatar.
Edited by The Mafia
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007050
Yes as Mr Mafia said get the real one which was and still is a HKS spec turbo , only sold through Garrett as well .
The real ones Garrett part number is 700382-10 using cartridge number 700177-7 .
Do it once do it right and think seriously about what he said about the 0.63 A/R turbine housing if lag troubles you at all .
A .
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007100
I had that issue in NZ back when I was trying to get a GT3076R for my car, all the local outfits kept telling me either its pretty much the same or that it was actually the one I wanted - I had to order from the states to get what I wanted in the end. There is definitely a pretty noticeable difference between the two, using this version would be regrettable.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007235
Thats what I told him mate. And now he is going to exchange the entire turbo (1 with the proper 6 fin and .60 A/R) so it should all be fine.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007661
A .
Thanks Disco.
I was wanting to still use the .82 housing, my mate has that housing on his 3076 and the lag on that doesn't trouble me at all, so I will stick with that.
And I would have to stick with the Garrett as thats all I can get a replacement for.
What is the difference between the 700382-12 (700382-5012) and 700382-10 (700382-5010) products? Is one 52trim and one 56trim? is there any difference?
Cheers
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007716
I don't know what reasoning you have for that, but its not the best recommendation you've made imho - especially after having had both myself. The .82 only loses any noticeable amount of go below 3000rpm, where isn't a place RB25s are "about" anyway. Above there the .82a/r feels nicer, is nicer on the engine (Mafia needed WMI to suppress detonation, I and others have battled boost creep with .63s) and naturally is capable of more power.
I never looked back from upgrading from the .63 to the .82 - though again the OP has obviously also experienced a "real" 56T with .82a/r hotside and knows how nice a setup they are to drive.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007757
I just sent the incorrect turbo back to them and told them I want the real 56T one which had the part number 700382-5012
I also told them to stick with the .82 rear housing. I wanted to keep the .82 housing as it has the potential of more power if I desire it.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6008036
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
