i went to the mechanics the other day to talm about a intake and they said i would gain more power out of my rb25de 4 door 25gt with a knN pannel filter and getting rid of the silncer pipe, i was thinking more along the lines of a custom intake box with a pod filter? whats better help guys
https://www.sau.com.au/forums/topic/376632-intake/
Go with a Pod Filter + Cold Air setup and purchase a Pod Heat shield from Just Jap for about 150.....makes the engine bay look Mad and Cops more likely to let you off a defect. My mate is always stressing he cant drive his R34 when the cops are out on the prowl because they will defect him for a Open Pod Filter, if your going for a Pod Filter get it closed up.
Edited by starwarz
https://www.sau.com.au/forums/topic/376632-intake/#findComment-6008963
Don't do it - you actually lose power if you remove it.
High flow filter is the only worthy thing changing.
I don't understand why people want to undo such good work a team of highly educated Nissan Engineers, with unlimited dyno time and with millions of R&D budget put in place.
https://www.sau.com.au/forums/topic/376632-intake/#findComment-6010010
cause doing fully sick mods will always gain killerwasps.........
/sarcasm
https://www.sau.com.au/forums/topic/376632-intake/#findComment-6010214
When i first got my 31 after about 6 months i put a k&n pod and cai kit on was ok felt more responsive etc, cop gave me a warning about it, i put old setup back on with new panel filter, felt the same response increase, 6 months later another new panel filter, once again it felt more responsive.
In short replace filters often (i also did all filters spark plugs and oil changes at the same time)
https://www.sau.com.au/forums/topic/376632-intake/#findComment-6010459
i removed my silencer pipes the intake is now louder and to me it feels more responsive but hey im no engineer just a med student :S i know nothing of blow of valves but i do bicuspid valves :P
i have heard a lot of possible mods but never removing Silence Piping....are these in the pipes before the AFM pinch.gif
https://www.sau.com.au/forums/topic/376632-intake/#findComment-6012026
  • 4 weeks later...
dont kno if n/a models still have holes cut under the air box (same chassis but never looked at an n/a one) but why not just make your own going through these two holes. completely away from your ingine and use high flow panel in air box with holes cut in bottom and pipes through these holes out infront of the sront passenger wheel
https://www.sau.com.au/forums/topic/376632-intake/#findComment-6047325
were they back to back tests on the same day, just a few minutes apart? if not then you can't rule out some variance due to weather differences, differences in how tightly the car is tied down, etc.
also the gains on a v35 will be different to an older rb motor. i'm guessing you'd see more gains on a v35 than on an rb
https://www.sau.com.au/forums/topic/376632-intake/#findComment-6048818
  • 1 month later...
  • 4 weeks later...
whats the go with the silencer pipes, where r these located?
If you look at your intake and have a feel around one is located just up from the maf a box on the bottom and where the intake connects to the throttle body there is a black box looking thing on the right of the throttle body. I just removed them and replaced them with aluminium tube from auto barn it looks cool :D
https://www.sau.com.au/forums/topic/376632-intake/#findComment-6158011
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
