Went for a drive this morning. After 5 minutes of driving I noticed that the temp gauge hasn't moved at all.
Pulled up at a red light and the car stalls. Managed to start to car but took some hard cranking. Once started the temp gauge jumped right up to midpoint (or normal temp).
I noticed that before stalling at the lights, I noticed the AFR were quite rich - around 12ish when usually they are 14-15 when I'm cruising.
Is this indicative of a failing thermostat and hence the car was running in cold loop?
https://www.sau.com.au/forums/topic/376888-random-stalling/
something like this happened to me the other night, randomly stalled then very hard to start afterwards. still takes a while to kick over at every start, but seems to run ok while driving. I'll have a look tomorrow and try find anything loose
https://www.sau.com.au/forums/topic/376888-random-stalling/#findComment-6012231
Well this happened again today. Engine was running rough and spluttering, and stalled on me as I crossed the Springvale station rail crossing :blink:
Almost shat my pants as the bells started ringing...and I could see a Vline train on the horizon...:wacko:
cranked the engine for a good 6-7 seconds and it caught on...limped into the Caltex and filled up on E85 (initially thought I was out of fuel but the tank only managed to take 68L before stopping so I would've had another 10L left)
started the engine again, temp gauge is dead. engine is going nuts, reving out to 3k rpm without me touching the pedal. Fun part was putting the car into gear from N to Drive when the engine is revving...scared the shit out of a few people at the servo...
Switched it off again and turned the engine back on again - temp gauge responded and shot straight to the "normal" temp position. Car drove fine all the way back to work...
Poor Scott - woke him up when I called him in a panic...:blush:
Edited by ironpaw
https://www.sau.com.au/forums/topic/376888-random-stalling/#findComment-6027423
Do u guys reckon it could be something to do with the brake switch cable? This seems to only happen with u guys that don't have the switch
doubt it....
What exactly happens in limp mode? Surely it doesn't stall your car, make it run rough, or rev the engine out when idle???
https://www.sau.com.au/forums/topic/376888-random-stalling/#findComment-6028797
doubt it....
You'd have to ask Scott, guy that blew mine I cant be too sure as it wasn't me.
https://www.sau.com.au/forums/topic/376888-random-stalling/#findComment-6029183
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
