  • Replies 40
Ive taken some pics and will upload tonight if not tomorrow.
i also have the centre console bracket, $10 should do for that.
no boot carpet though.......
pm me when its a good time to pickup
hey guys, for those who have pmd or are awaiting parts im terribly sorry, mrs was in hspital for a bit so i havent been on.
outstanding parts ar being sent today for those waiting.
i will respond to all pms today at some stage.
1320053511[/url]' post='6087463']
do you still have exhaust manifold for turbo and if so is it t3 or t4?? eboost 2 still available?
both sold mate sorry, have t3/t4 turbo which needs a rebuild and split dump for ext wastegate available.
  • 3 weeks later...
sorry mate only have coupe lights.
Remaining parts left:
Rb20det assembled block and head only - suit rebuild $200
R200 Diff - $300
Harmonic balancer - $90
Power Mirrors both sides - $60 per side
Rear taillights - 2 door - $60 per side
alternator - $100
Rear crossmember - $80
T04E Turbo needs rebuild $80
Split Dump 9stainless) suit t04e with ext gate - $100
Fujitsubo catback - $150
Climate Conrol unit - $50
Knock Sensors - $50
Tailshaft - $100
Rear bumper brackets - $50
Engine mount brackets $50
Power window/mirror switch from drivers door card - $70
Rear lower 1/4 interior trims - good condition - $50 per side
centre console trim - $60
Lower dash to centre console trim - $60
Rear brake 2 pot calipers - $100
Narva Blue Power h3 headlight bulbs NIP $50
Orange indicator lights - $50 per side
Drivers headlight - $60
That all i got left.......the rest will go with the shell.
Ian
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
