Rich and retard. Its an ecu failsafe to try and protect the motor from being overboosted.
makes sense. what sort of pressure does this normaly happen at. What are the symptoms? black smoke, lacking power, or does it cut out
Happened to me at only 10psi in my old car. As soon as I hit boost 2500, it comes on nice and hard then all power and torque vanish after about 4500rpm. Its flat shit the whole way. Don't usually see too much smoke from a stock ecu. Wait til you go aftermarket, this BMW driver was swearing his nut off after tailgaiting me then me planting it and shitting black shit all over him.
That is a very good reason to keep the stock ecu. Our maybe next time one of these idiot perth drivers tailgates me I'll just richen it up to 9 to one while I'm driving. And plant it. Thanks for the good idea.
hahhahahahahaaa,, I can just imagine this....
"HERE TAKE THIS DICKHEAD" then fowl your spark plugs, engine stalls, pull over on side of the road.... get your head punched in, change / clean spark plugs.... drive home.
who is the dickhead now ? LOL
and about R&R, look at the maps on the R33 to understand it more.
Hmmm...my plugs wouldn't foul for starters as when intercooler pipes have come unclamped it has run this rich and not fouled or stalled. Secondly I am a fit 6"1 92kg 31 year old man. Who was going to punch my head in again? Not many. As far as dickheads go I would say that driving so close to someones car that it is risking your rear bumper is being a dickhead. I had a f**king truck run into me in traffic a few weeks back cos he was driving like an idiot and tailgating me. I am not happy about tailgaters :rant: So imagine this...you are tailgating a white skyline, your car gets covered in soot cos you were being a dickhead and tailgating me. Then when you get out being all macho you see me get out. Then you either apologise and get back in your car or get knocked out. My patience is gone for that sort of shit. So if anyone gets any ideas then please get out of your car so I can release some frustration on you and your car.
Ive read the term R&R being used quit often on the forum, in regards to the std ecu when too much boost is seen. think my car is suffering from this on occasions. what is it exactly
It a region on the airflow vs rpm maps in the ECU where the mixtures are very rich and the timing very low. The ECU doesn't expect the engine to ever get to those cells in normal operation, and that implies that there is some kind of fault so extremely conservative fuel/timing is used to protect the motor.
Bumping up the boost increases airflow and pushes the ECU into the R+R region of the maps.
No, it's a separate map of TP vs RPM that when the TP goes over that threshold timing is pulled and fuel added.
That being said, the top ends of the factory maps are so rich it's not funny, over a certain point the injectors are fully open! (saw 150% duty cycle :laugh:)
Rich and retard as others have stated are just an area of the factory map which would normally be called a "hole" a poor tuner had left in a map - but argueably done intentionally when airflow gets high in parts of the rev range for reasons best known to Nissan. Possibly done to protect the engine? Not that I know of anyone having reliability issues when tuning the car properly in those zones. I think it was a stupid way to let the car leave the factory, personally.
Short Samoan guys would be a good bunch to avoid in the first instance:
:whistling: Best policy is not testing the waters to find out, as naturally the one who does will no doubt be the one you didn't expect to be able to.
Maybe I am wrong on this - I was sure I've seen snapshots of this part of the map, so you are saying that regardless of the AFM signal etc there is a certain amount of timing pulled and fuel added? I would have thought this would have been more noticeable in a standard car, but you stand on the gas with the stock boost control etc and have no issues.... then add airflow and suddenly have the massive detuned sensation.
So where does the TP Load Limit table come into it then?
What I am saying is that while that top corner of the map is extremely rich (look at the required duty cycle to reach the target AFR in those cells, it's up around 150%), there is a table called TP Load Limit, which is the "afm (boost) cut" that people talk of. It tends to be maxed out in the lower RPM and decreases as the RPM increases. When your TP goes over this threshold is when "R&R" is encountered. What the ECU actually does in this instance I'm not sure (as in how much timing and fuel is altered and where it is referenced from, I do not know).
TP load limit is a hard limit for cutting fuel. If it hits TP load limit you WILL know about it.
R&R is a protective area on the last 2 columns (especially the last column) of the map which both increases fuel and even more drastically decreases timing. It is especially prevalent around the 4000 to 5200rpm area - you can imagine this visually by looking at the dramatic timing drop in the last cell. It is airflow based so efficiency improvements will also contribute to getting into this area as well as boost - the initial signs typically start around 9psi and getting dramatically worse towards 14psi. The onset of R&R is much more gradual than TP load limit. Kinda like developing liver disease as opposed to being shot.
Edited by simpletool
Mate you'd be pissed too if your car got hit by a truck. I reckon best policy is don't tailgate and your car will stay clean. :thumbsup: Here comes the soot :ninja:
Back on topic r an r is gay. TP load limit will make you shit yourself when it happens. Had both and fixed them with a power fc :merli:
I'm pretty sure there is MIN and MAX TP tables, separate to the TP Load limit.
I will load up NIStune when I get home and take some screenshots.
Ok, this is from the nissan_ecu_tuning_basics.pdf on the NIStune website..
9. TTPmax & TTPmin
TTPmin = “Total Theoretical Pulsewidth Minimum”. This value sets the absolute minimum injection
pulsewidth. This is in case a calculation (eg: unusually low reading from AFM) results in an injection
pulsewidth which would cause the engine to stall. Normally this value is only adjusted if different injectors
are fitted. Multiply all values by the ratio of old injector size vs new injector size.
Similar deal for TTPmax. It limits the maximum pulsewidth that will be used under any conditions and
values are modified in the same way. Watch out if TTPmax is set too low – it will limit the injector
pulsewidth and you won’t be able to richen the mixtures no matter what values you put in the fuel maps.
12. TP Load Limit
Commonly referred to as “Boost Cut”. Many tuners set all values to 255, effectively eliminating boost cut.
But a better strategy (assuming boost has been increased) is to adjust the values so that a boost cut still
exists but at a higher level. Values refer to TP, so work out what your max TP is and then adjust the
numbers in this table to slightly over this figure. This gives protection if boost control is lost (which can
easily happen if for example the hose to the WG actuator becomes damaged or dislodged).
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
