63 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Silver is a common colour to use, or some have done some kind of tungsten? i think colour ... they both look good
I think it was 666DAN that did a thread on this ages ago, tons of people have posted pics there and you could probably get an idea of a nice colour from that thread :) I did mine silver
https://www.sau.com.au/forums/topic/377348-yay-or-nay/#findComment-6018406
Definitely nay confused.gif If you kept going, that could end up in the "What not to do to a Skyline" thread.
I skinned mine with carbon fiber cloth. But that's damn expensive. And not easy to get a good finish, would probably be better sticking with paint. The trick is to not make it stand out too much, you want something that compliments the rest of the interior, not becomes the only focus of it.
https://www.sau.com.au/forums/topic/377348-yay-or-nay/#findComment-6018466
Nay, had a mate re trim his whole interior with a tan leather (im talking like vibrant yellow) looks like puss. and another one with a 300ZX re trim in
a fluro green. In general id avoid it unless your 100% sure its what you want :P
https://www.sau.com.au/forums/topic/377348-yay-or-nay/#findComment-6018502
Oh man, your not gonna tell me your gonna undo something you like because other people don't like it. Stand up for yourself!
It aint my style, but I rekon it would look better in black if you wanted to keep the texture, and minimize the complaints :thumbsup:
https://www.sau.com.au/forums/topic/377348-yay-or-nay/#findComment-6019225
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
