This was delivered earlier today............
In other news....
Going to spruce up the rims as best I can and then put all four on the car to narrow down what tyre specs I want to run.
Leaning towards 245s 40/45 18 (common size and therefore cheaper) - though I would like to run 255s.
Also debating what tyres to run.....tossing up between Ku31s, Sumitomo z111s and Toyo T1 sport
Awesome choice of wheels Jez. Got a photo with them on? I reckon it will transform the look of your car totally and the dish will suit the black-on-black theme you've got going...
Thanks - I do :wub: them.....
Will post pics asap.
Black centres... whats the sizing?
OH MAN...Don't start that again :domokun:
(I can hear Jonno screaming "all black" and my brain screaming "gold with silver lip" and you going "black centres please - thanks" - noooooooo its in my head !!!)
18x9 +35
Don't forget to look at the Nitto Invo Pro; killer spec for the price.
Those rims will definitely be a slick addition.
Cheers Dale...will check.
Any recommendations on where to pick up tyres from btw??
I pm'd Taleb Tyres on here but no reply yet.
Anyone bought anything from Ozzytyres?? - seemingly awesome pricing.
Amazing work! I'm glad to see someone else taking the one colour look so well.
(One day I'll make everything blue!)
Thanks man........plan to still keep the silver lip though even if I do powder coat the centres.
I like blue :geek:
Damn those rims look sexy as fark!
Love how this car has come along
Thanks mate :) There was a time when I was tempted to go with your setup (black on black looks killer too).
ITS MY BIRTHDAY !! :banana:
Went for a trial fit this morning to my local tyre place to finalize sizing etc.
As of now I am going to run 235/40R18 fronts and 255/35R18 rears
Will be ordering my new tyres soon.
Also, want the car looking the way I want it now so going to run 10 or 12 mm bolt on hubcentric spacers on the fronts to get the wheels looking a tad more agressive. (provided I find some - only found 15s so far) There is no way in hell I am running slip ons - say what you may!
Will not have to change the factory bolts as the rims have space for the protrusions (yay!!)....so might end up running spacers on the back as well. (P.S. I am aware of the legal stuff).
Stay tuned.
Edited by jez NF
its looking tougher with those rims, nice work :)
I want one of those seat covers.. lol
You no get ma seat cover niggaaaa !!
Update:
Ordered these this morning....
Could not find bolt on spacers in less than 15mm so ordered a set (see below)
where I get the two 15mm bolt ons that I need and a few extras to play with when "posing" !! :cool:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
