Just had a quick google search. Here is it if your interested
http://www.carmate.com/product_details.php?productid=NSGTS95TSBOOT
Thanks heaps.......looks good...will factor in postage and painting etc and see if a DIY / fabrication option is more feasible.
Update:
Bought a stock boot lid off Jarrad ( :thanks: ).
Project GT wing has begun !! WOOOHOOO!!
Also....earlier this evening Aaron from Westy's Warehouse went out of his way to fit and balance my new tyres and finish everything today itself - absolutely sensational service and top bloke.
..and....I will not need that spoiler on there...so if anyone wants it....it is for sale..chuck me an offer.
Very very productive day so far.
Woke up bright and early with the sun streaming in. Just knew it was going to be a warm one. Polished up my new Ganadors and proceeded to install them (you know your obsessed when you start car stuff before brushing your teeth!!)
First step: remove door trims...
Passenger side: Three screws down at the bottom of the door panel. One screw inside the little plastic pocket thing and one screw underneath the passenger side handle / arm rest.
c063729d-97e7-4be0-8cb6-82081a12426b_zps
Drivers side: Three screws down at the bottom of the door panel. One screw under the switch plastic panel.
Both sides door release plastic surrounds need to be pried off.
aae1bead-52b2-41ef-8704-0a92a44df645_zps
Then remove plastic triangle to reveal three bolts holding mirror in place. Remove and unplug mirror. Plug Ganadors in, secure wire and put it all back together. Did not get a picture of the mirrors...but will post some when I do the photoshoot (sometime soon)
Then started fabrication work / planning for the GT wing project.
50bdf1ba-8f50-4608-98a0-07b569e9ce87_zps
Tried...but got more love from pete who gave me some suspension tips..the tall dude whos name i cant remember who chatted for ages about his big block chevy and new zealand and the most from rob the alignment guy who everyone seems afraid of...lachlan was probably having an off day...lol....overall a good experience
New rims set it off nicely. Cant wait to see the boot DIY you got going on
I LOVE THEM TO BITS...... :wub:
c4ba2ff5-99f7-4409-b0a9-965050bda5d9_zps
Just needs a fraction more aggressiveness on the rears...which I will achieve as soon as I get the guards rolled.
67bbf14c-6573-47f5-9e1e-1afdb03def25_zps
Yeah the wing is a radical idea to say the least....I am hoping it pays off !!
Keeping with the stealth look under the hood I swapped pod filters this afternoon.......
92e0f407-12ef-41fd-bb28-6b00309a1e6b_zps
Engine bay still needs major sprucing up and is only quarter way done...with the rocker covers next on the list for a nice black refresh !!
bf348702-219e-453e-b931-2fac82dd5d60_zps
Getting some Whiteline swaybars next......24mm and 22mm front and rear respectively...adjustable. Thoughts / suggestions / anything I need to know??
Reliable sources tell me they are possibly the best bang for buck upgrade suspension wise.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
