  • Replies 71
I've got my drum sitting on a few wood chocks just to keep it off the concrete...
In terms of pump, I use a jiggle siphon for about the first barrel as it's nice and easy. I also have a rotary barrel pump for the second half of the tank. It takes a little more time to attach but pumps really quick and easy. When I'm finished I always seal back up the drum :)
anyone using the macnaught rapidflo?
http://www.macnaught.com.au/shop/item/rapidflo
or the alemite version..
www.alemite-lubrequip.com.au/Portals/0/ServiceSheets/5080A.pdf
keen on one of these but $500 is a bit expensive for something i'll use once a month.
anyone know where to source these cheaper?
redistrip at blacktown....the guys at sucrogen asked them to sell the fuel cause they're close to EC and have the appropriate licences to store it.
they know very little about e85 or of any fuel transfer systems.
what's the transfer rate with the std pump? can't remember....been a while since i had a std pump.
Edited by tk80
PIGGAZ and I use a stock gtr fuel pump and a basic switch with alligator clips for power. Could be made to work from mains power with a bit of effort. Costs a lot less than $500
That's not a half bad idea haha
Might have to give that a go :)
I use an Alemite diesel rotary pump, but the ethanol dries out the gears so it can be difficult to prime. I open it up between each drum and re-lube the gear and race.
To refuel at events I use a cheap $30 go-kart battery pump from 20L drums. The 2 D cells last around a dozen or so 20L drums!
It's funny as shit to watch the pair of them stuffing around with a good 10 jerry cans @ any event, then their little motorised pump is lol :D
But it works. It's a damn good convo starter too!!
I'd say it empties a 20 litre can in 3 minutes ( I need to time it... I'll do that next time). Not the quickest way, but a shit load easier!
+1 Sounds like hard work. Conventional plastic jerry can with breather hole size bored out = quick dump of fuel into the tank with hardly any effort.
It's pretty handy when you want to throw 3 full jerries in, instead of standing there in the sun holding 20 kgs for minutes on end.
As long as ya keep the drums up off the ground i.e on a pallet or something similar they will last longer than it'll take you to burn it up lol.. Just make sure ya seal the drum after ya open it up as it will suck in the moisture.
  • 4 months later...
http://www.gettoolsdirect.com.au/fuel-transfer-equipment/macnaught-gp-rapid-flow-hand-pump.html
just used mine for the first time and couldn't be happier. expensive but does the job very quickly and very easily. emptied every last drop from drum without tilting also.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
