Title says it, I went overseas for a month and the car was left in the back yard with a tarp covering the entire car. My sister left the magnetic p plate on the back and every day the heat produced must of welded the damn thing to the boot.
I've managed to get a minor part of it off on a fairly warm day.
Any suggestions? Warm water? Hair dryer? Any chemicals I could use to remove it without damaging the paint?
Will upload pics tomorrow :(
Thanks in advanced :)
I would think as you have suggested - but no experience with this kind of thing, worst case scenario is repainting the boot lid so I suggest see what else gets suggested and give it a go. Good luck.
Bug and tar off fishing wire and a heat gun and alot off patience and beer needed for this job ive done it many a time to ex gfs cars lol since there mistakes ive now changed back to the good old plastic ones lol
Dental floss, because it's waxed and flatter than fishing wire.
+1
BTW does the company that makes those "Magnetic P" plates have a disclaimer (or at least a warning) against damaging a car?
Sigh, I presume you'd have to start the legal process in China > get nowhere fast.
yep seen it happen only thing at took it off was ecucalyptus oil (i know i have spelt that wrong lol if that fails carby cleaner or fly spray belive it or not
Best of luck :)
or lavender oil
  • 3 months later...
  • 2 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
