I have two bootlids, one is plain, the other has the std R34 GTR wing on it. I only did a 6-8 laps at Winton with the rear spoiler and I dont think it makes much of a difference. When I get a chance I want to throw the wings and boot lids on a trailer and test one day at Winton...since I am moving to within a 45min drive of Winton for a project there are going to be plenty of Friday practices that I run down for
Uhuh. I have two boots as well, one with replica 32 GTR wing and Nismo lip, other with ARC alloy wing with adjustable gurney flap. ARC defs creates more rear downforce, but unbalanced it front to rear (I don't have a front splitter).
Suprisingly, adding the Nismo lip to the stock GTR wing made a noticable difference. Evidently creates a high pressure zone atop the boot lid.
Well, I have a front undertray, though its not on the car at the moment as it makes a wheel alignment a pain and I need to get the car aligned and the oil cooler installed properly as the panel beater all that time ago didnt have the time to mount it properly. Also makes it a pain to get to the brake air guides etc which I can now finally finish because the Stoptechs are on and never coming off
So when the boot lid goes on I will have the undertray on
I have an undertray/skid plate, it made a small improvement but no match for "big wing like Mig fighter jet" (Russian accent)
I hope to get the mojo to make a front splitter extension about 4/5 inches to actually get some front downforce, rather than just trying to minimise lift.
you want voltex wing big boy. bit expensive but heaps good white man magic.
either that or use the C-West GT wing II - Suzuka like what I sold berry for his R34 (in it's V1 guise). they make R34 bolt on version and it works bloody well.
Thanks for the heads up.
It would be good if I could put a leading edge lip on the front of my undertray. Will e easy to do, only problem is I drive my car daily so god knows the Cossie is a nightmare being only 50mm off the ground...dont want the R32 to be the same so would have to be removable for daily driving duties....the ideal solution I have is too expensive so wont go there :)
if you've got two boot lids, so who cares how many holes there are in one of them?
I'm sure expensive Voltex wings are very good, but my $300 CF China wing worked well enough to totally transfom my car from near uncontrolable oversteer to plough understeerer in back to back sessions on the same day not touching anything else on the car. While only costing ~3kph in top speed, but that was into a headwind that day... And it dented the hatch in on my 180SX. I went 7 tenths quicker than before on those tyres, while being very compromised by understeer. If you could balance that out with front aero, you'd easily make at least that much time again. probably more. If a $3000 Voltex wing works better, its only going to make your life more difficult to get enough front aero.
The gurney flap would make a difference. But a dual plane wing is technically a better solution. You need one of these...but woudl cost waaaaay more
But, truth is I dont pretend to know that much about aero. To me its all wank for 99% of us. We end up with ugly cars with parachutes attached...but there are a few basic concepts that seem best to follow
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
