I recently brought an R33 GTSt series 2, on the way home i noticed from 3500 under boost it just doesnt pull very hard. I changed the plugs to PFR5G's gapped to .7 and just replaced the splitfire coils with yellow jackets but didnt help so i assume my splitfires are ok.
The car runs good for about 5 mins then starts playing up like this sometimes when it hits 5000 revs it misses and backfires, If i stop the car turn it off restart it and take off its fine for a few mins then plays up again
As far as i know the car has a high flowed turbo thats all i know about that, 3 inch exhaust and dump pipe running factory boost. Im not sure where to go from here its getting to be a pain! maybe AFM ? i dont think its Rich & Retard as it does it at only a few psi
Oh and i have searched and read numerous theads on this forum i dont mean to offend anyone by posting another thread on this topic but i dont think i have read one where restarting the car temporarily fixes the issue
Sorry I can't help you with this but all I can say is I have the same problem. With my problem it pushes you back in the seat around 2.5k and then from 3k - 5k or so it becomes a lot of noise and not much go and after that it starts to pull a lot harder. Is that like yours? I've just put in new plugs and Yellow Jacket coilpacks and it's still doing it. I think you and I might have a Vac/Boost leak somewhere..
Thats pretty much exactly what its doing!
Just read the fault codes and its coming back with code 21 = Ignition signal, Ill reset the ecu by disconecting the battery and see how i go
Problems back!
Disconnecting the battery fixed it for a day then it started playing up again, since then i have replaced the AFM with a brand new one but the problem is still there and still intermittent like before, iv got no idea where to go from here
highflow turbo + standard ECU = asking for trouble of the kind exactly like you are describing.
standard boost or not the turbo is flowing more air than the ECU can handle so its chucking a hissy fit
I cant seem to lower the boost, it boosts to 0.5 Bar then after 4500 revs the boost starts building with revs until redline and then its boosting 0.8 - 0.9 Bar.
I have a vacuum line running straight to the wastegate bypassing the boost control solenoid. Does the boost rise because the wastegate cant flow more exhaust gas due to it now being highflowed ?
Having given the fault code for ignition signal surely you would want to test the CAS?
I too am having this problem as is another member and i am certain its a damaged CAS.
I'll give mine a go soon and report back, not sure how early ill be doing this but sometime next week is on the cards.
Definatly rich and retard, I did some data logging and when the AFM voltage reaches 4.4 or so the timing pulls right back to 0 Deg BTDC and injector duty shoots up
Any ideas on how i can stop the boost creeping from .5 bar to .8-9 at redline ?
Run the standard wastegate spring, it sounds like you have an rb20 item in there if its running 14psi. That or there is a leak in your wastegate vacuum hoses
Its a vicious cycle, the car hits rich and retard, dumps in a whole lot more fuel, which in turn helps spool the turbo even more. I spent nearly 2 years trying to figure out what was happening and why i couldnt get my boost to stabilise. I only ever found one solution that allowed me to keep the boost stable, and that was putting a 2.5" restriction plate at the end of the exhaust. No idea why it worked, but with that in i could set the boost to whatever i wanted and it would hold it to redline, take it out and it would do what you described, just keep building boost to redline. In the end i just got a tune to 14psi and let it do what it wants, its seriously the least painful option, trying to run anything over stock boost with the standard ecu and tune is just a massive headache with rb25s, you need to either pick standard or pick your mods then get a tune, there isnt really an inbetween that wont cause issues
wut
2.5" plate after the end of the turbo? that is the most retarded idea I have ever heard, why didn't you just get it tuned properly from the get go?
it was at the end of the exhaust, a few people mentioned it as a common problem with supra's , and a few had had success with it here. It was by no means a solution, but i was trying to figure out what the issue was before i went and got a tune
Edited by Sparky206
Well i just had a look at my ecu and it has one of those gold mines stickers on it
That is your problem right there, go get a stock ecu. Those mines ECUs are rubbish, make it run way too much timing, way too rich and just suck ass.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
