you can use a odb2 cable with some software to to read your fault codes, i use a bluetooth obd2 sender in my s2 and my tablet pc with software reads me the codes all up didnt even cost me 50 bucks....
http://www.skylinesa...52#entry5616852
post #5 tells you the procedure for a M35
haven't found it for C34 yet
http://www.skylinesaustralia.com/forums/topic/266512-reading-nissan-fault-codes-ecu-fault-codes-how-read-them/
Ok this may work for C34 - too dark to try it now.
You need to find the consult plug which on my car is behind the coin tray next to the fuse block.
S1 is consult, I would have thought S2 would be too (they predate OBD2).
I've looked at 2001 Subaru's that are fitted with OBD2 connectors, but only 'speak' SSM (Subaru Select Monitor).
thats right. S2's are also consult the same as the S1's, and R34's, and R33's etc etc.
Simon, the S2's fault codes and how to retrieve them are the same as the R34 RB25 Neo's. are you looking to pull the codes from you S14? if you have the consult plug wired up, and the engine check light too, you can use the "paperclip method" to bridge out the two pins to get the error code to flash out on the dash.
otherwise you can use any consult lead and software to check them i.e. Nistune, ECUTalk, Nissan Datascan, Tecu etc. this also depends on a consult plug being hooked up.
  • 1 year later...
Hello gentlemen,it's been a long time since the last time here,,,and sorry to bring back this conversation but after suffering the engine light going off and the car acting weird I did the clip trick and obtained CODE 21 and as apears in the guide it should be IGNITION SIGNAL ;after trying to find a way anybody solved it ,looks like it's coilpacks related but,could it be the CAS ,I discovered that when the light goes off an extrange sound comes from the block ,it's like something rubing...Any suggestion or advise will be apreciate.Thanks.
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
