Guys
I've just put a deposit on a 2000 model DAYZ RS4S (ie manual) in black. Currently its only got a catback, but i have a bunch of stuff to go on it.
I'm moving from an S1 C34 auto (RWD), and I feel this is a decent minor upgrade
Seems I cant find heaps of info on this model though. I'm wondering about stuff like clutch upgrade, and whether these can be nistuned like all other Neo's. How much power can the stock clutch and gearbox take? (I have parts floating around for about 270-280rwkw). Do they have LSD in the rear?
How many of you guys have RS4S'? What do you think of them?
Thanks in advance for your replies
https://www.sau.com.au/forums/topic/379150-educate-me-on-c34-rs4s/
SEARCH IS YOUR FRIEND. But im nice so here ya go.
Clutch upgrade is the same as skyline. Recommended first mod the stock clutch has zero clamp force and won't even hold the stock power.
R34 engine = type 4 nistune.
People are making 300+ with stock gearbox
Front and rear LSD.
There is lots of rs4s owners on here.
hmmm, my clutch is holding out 220kw, no slipping, unless i dump the clutch at 5.5krpm and above in 4wd mode, then i get a slight slip.
clutch is 30k km old.
but they are def a fun car to own. just make sure you do some decent stability mods, they handle pretty bad.
Ok so i just took delivery of it. Drives great except that it crunches into 4th gear, so i'll need to get that looked at
Regarding suspension, I've already got the following ready to install
Tein coilovers
Cusco Castor Rods
Whiteline swaybars
Adjustable front upper arms
Cusco Adjustable rear upper arms.
Alloy subframe lock kit
Is it worth getting a hicas lock kit? I'm not a big fan of letting the electronics decide what direction I should be going so i'm tempted to do that
This thing is a bit slow compared to our other stageas. I'm sure the 3076 i'll be installing on it shortly should resolve that issue though :)
Are Dayz S2 RS4S in black a common thing? I dont recall having seen one before
Also WHY NO CUPHOLDERS!??!! There must be a reason they decided to install a blanking plate on the RS4S' rather than the cup holders under the stereo.
There are two small cup holder recesses in the centre console.
I would be interested to see how you how you with a GT3076. The manual stagea is a big lump to get off the line and I think it might be a bit docile down low but will haul once a few revs are onboard.
The stock clutch will hold reasonable power. Mine was FUBAR'ed on arriving from Japan and wouldn't hold decent power on the dyno. I went through two cushioned button clutches. The first had issues from the date of install and was replaced soon after. The 2nd one was a pain in the arse to use on inclined roads in traffic due to the weight of the stagea, it bogs down so easily with a button clutch or you need to launch it.
The current NPC clutch is so much better for the street. NPC higher clamp organic clutch is a gem.
The reason for no cup holders is you wouldn't be able to pull them out when your in 1st, 3rd or 5th
Pfft, they're fine where they are. Mine's a converted car (s1 with R32 GT-R box), and I can still use the cup holders under the stereo while driving.
Im curious as to why you would want cup holders anyway, that's what legs are for. After driving classic toyotas for the last 8 years I haven't even considered cup holders to actually hold a drink of any kind, my cup holders in the stagea hold the bolts that don't fit anywhere/fall off and my garage door button.
Not a bad example of a stagea.
Ok i'm going to stick some cupholders back in. Worst case is I'll bump the cups when changing gears.
LOL at using legs to hold the cups. You obviously aren't driving hard enough! :)
Hopefully my new stagea will have some significant changes over the next few weeks
hey mate if you got all this gear to go in your rs4s i hope the coilovers etc didnt come out of an rs4v cos they wont fit.
coilovers is the best thing i did to mine for better 'drivability' aka doesnt feel like your cornering in the titanic
rear is an active LSD, my rear wheels skip like a locked diff when turning close to full-lock
i actually like hicas and dont understand why people hate it so much
because old hicas tends to play up and get really buggy/worn/does random stuff
new hicas is good unless your on a track and know the exact conditions etc
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
