STOLEN EARLY THIS MORNING FROM KIDMAN PARK AREA REGO: Xtl607
car is on defect and should get attention from our mates in blue. hopefully...
If you see it call Jason on 0413 329 084
for all you nazi's, it did have an alarm n the rest of it....
https://www.sau.com.au/forums/topic/379205-stolen-r32-gtst/
this looks like the car from mason lakesis today if its the same car had lots of stickers like this one same color and the wheels was black to seen it was about 1pm and seen it going in to manson lakesis from main noth rd and when i was coming back home around 6.30pm seen it come out of manson lakeis on to sudbury highway turning left on to main noth rd and had cannon on the back did not look at the plates sorry did not know it was up here good luck getting it back
https://www.sau.com.au/forums/topic/379205-stolen-r32-gtst/#findComment-6050026
English dude. Please learn
https://www.sau.com.au/forums/topic/379205-stolen-r32-gtst/#findComment-6050082
Fu#$wits, I own a R32 GTR license plates GDZILA. At 5pm yesterday I got home, a mate came over and stayed for 15min tops. When he left he noticed a car half parked accross my driveway but thought nothing of it. I went out the front 5min later and saw my drivers door wide open. Checked inside and my ignition barrel was rooted..... Failed attempt to steal in broad daylight, on a busy street and 3 metres from my front door!!!
My pride and joy is now in storage and staying there for good.
NOW FOR SALE $28,000 Attracts too many wankers :( PM me if interested
Mate described theives in a green VN-VR sedan front passenger of dark skin apperance... For their sake hopefully someone catches them before I do!
https://www.sau.com.au/forums/topic/379205-stolen-r32-gtst/#findComment-6050183
Holy crap. Happening in broad daylight and just a couple of meters from the front door, knowing that the person who owns the car is inside, f**k. Seriously someone is going to get injured badly if this goes wrong. Imagine the owner stepping outside, unaware of the scum that is trying to steal his car, the theif most likely will have a weapon and the owner could get hurt in this scenario
https://www.sau.com.au/forums/topic/379205-stolen-r32-gtst/#findComment-6053008
after all these thefts i've stopped parking the GTR out the front of my house. i've taken it to the mrs parents house to put it in their garage and behind some bolted gates.
i heard about the car being stolen from hove which is down the road from me and they didnt even have to start it. they just towed it away.
i was so paranoid over the weekend, i thought i heard some people talking out the front of the house with a toolbox so i grabbed the maglite and went to the window to check but nobody was there.
if they were they would've gotten a maglite across the cheek.
i'll only be leaving the car out the front once i get the 2m gate out the front and some flood lights.
https://www.sau.com.au/forums/topic/379205-stolen-r32-gtst/#findComment-6053104
two attempts in west beach area last weekend to steal cars, and these guys were violent, also described as being in a silver r33 gtst that was dosing. happened overnight to a gtr and gtst. luckily both cars werent actually taken.
lock your cars up and if you dont have any security system i suggest you invest. do what you can to ensure if they do somehow try, they cannot possibly take the car.
https://www.sau.com.au/forums/topic/379205-stolen-r32-gtst/#findComment-6054539
  • 3 weeks later...
Couldn't agree more, the last thing you fellas want to face is a strung out junkie stealing your car
By you fellas I look at those wanting to setup stings, I know a lot of it is e-talk but...
hey mate it was my car that got stolen....... id be keen as for a sting :D just put a car somewhere with the door cracked open so the interior light is on and sit and wait from a distance........ when they approach the car BAM bust there heads clean open :D if you really are keen to do it let me know :)
https://www.sau.com.au/forums/topic/379205-stolen-r32-gtst/#findComment-6084441
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
