  • Replies 162
oh and did anyone else think that perkat shouldn't be let near a microphone again? comes across as an absolute twat. i think he is now my least favourite driver. probably even more annoying than vetool.
+1
It wasn't queueing that cost 888 the win as the time is recovered when sitting behind the safety car, what lost 888 the win was the group of cars traveling behind 88 when Whincup had that battery issue, Tander was already past 88 and in the pits and 888 was stuck about 5 cars behind 88 across the top of the mountain at walking speeds...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
