As the title says I want a triple gauge pod for 60mm gauges for either the dash or A pillar, looked on eBay and found nothing, just jap have nothing
After a model specific one
Can some one point me in the right direction
Cheers dan
https://www.sau.com.au/forums/topic/379554-r33-60mm-triple-gauge-pod/
  • 3 weeks later...
border make them.
you can buy them here.
http://www.rhdjapan.com/border-tri-eye-onboard-meter-panel-53186
Just for future searching, not that any one searches these days, the border doesn't mount where the above picture shows, it's further over the passenger side, and with a S2 it sits on top of the airbag cover, could make for an interesting deployment.
Dan
i think that the top one is a border pod however the bottom one just aint the r33 specific one, although i could be wrong.
i want the top one if it is the border
It is not, that's what I wanted and did not receive,
  • 1 year later...
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
