This is my current project, a 1993 Daihatsu Mira, 659cc of pure 3 cylinder power.
these thing weigh around 550kg and have a huge 32kw of power.
Plan is to use it as a daily and enter some Motorkhana action in it, get the missus out there and let her tear up the bitumen.
Spotted this for sale ages ago, but def didn't need it at the price that was being asked, but i saw it had potential.
So someone else snapped it up, drove it around for a while and well and truly molested it, then he broke it
I saw it up on the forums as a give away, grabbed the bosses tow car and trailer and went to pick it up, I gave the owner some cash toward the rego and some beers too.
Turns out the clutch was knackered and the LHF hub was stripped of all its splines.
Time for the motor to come out, with the help of my lovely wife we got the car in pieces
Motor out and box off, we replaced the clutch and the clutch lever. put it all back in and replaced the LHF hub.
https://www.sau.com.au/forums/topic/379694-project-dave/
And then one of the lads mention he had some WRX Recaros laying around in the shed.
So now i have to make him a new dump pipe for his S14 and a full 3" system in exchange for them but i do have sick seats
cut the old mounts off of the rails and welded some new tabs on, all fairly easy really
https://www.sau.com.au/forums/topic/379694-project-dave/#findComment-6055388
Stripped the tyres off of the rims and started stripping all of the paint off, still unsure whether to paint them black or get them powdercoated white, sorta all depends on the colour of the car.
they ar 12 x 6 minilite style rims, they don't sit anywhere near inside the gaurds, so i have some 145 tyres to stretch onto them, might have to pump the gaurds slightly once the car is lowered
https://www.sau.com.au/forums/topic/379694-project-dave/#findComment-6055418
Maybe, can get turbos for these for under $200, then i can just make a manifold and retune. it's already EFI so it's be easy. gotta get it back on the road first.
i was thinking more along the lines of a turbo Charade conversion, you could go from 55hp to a massive 68hp!!!:laugh:
Edited by tweety bird
https://www.sau.com.au/forums/topic/379694-project-dave/#findComment-6055458
maybe if the motor lets go, we'll see what happens once i make up some headers and better flowing exhaust for this motor first, gonna strap it on the dyno for before and after runsthumbsup.gif
https://www.sau.com.au/forums/topic/379694-project-dave/#findComment-6055478
cool, i look forward to it. :thumbsup:
https://www.sau.com.au/forums/topic/379694-project-dave/#findComment-6055507
got some more work done over the weekend, polished the outside lip of the rims and painted the centres all black, just gotta fit tyres up tomorrow at work
then i continued the boring job of bodywork, roof and bonnet all rubbed back, all the hideous pink flames are gone and the bonnet has been smoothed out and primered up.
https://www.sau.com.au/forums/topic/379694-project-dave/#findComment-6063901
dropped the tyres on the rims tonight, brand new 145/70 12's for the front and secondhand 165/60 12's on the rear,
these will get torn up by the bitumen when the motorkhana hand brake action begins, so i don't want to waste any good tyres back there
Hope to do some more bodywork tomorrow and get started on the big bore 2 1/4" exhaust on the weekendthumbsup.gif
https://www.sau.com.au/forums/topic/379694-project-dave/#findComment-6066319
Got some more work done today, flushed the old Black coolant out of the engine.
Then I had some fun, time for low, started lowering and just couldnt stop, now Dave is a Slammed Mira.
The front looks a bit higher, but it actually sits dead even along the sill panel. just need to lip the rear guards a bit more.
Did some more body work too, straightened out the lip on the front guards and started to tidy up the tailgate, then they got a coat of primer.
https://www.sau.com.au/forums/topic/379694-project-dave/#findComment-6074305
got some work done on the Mira over the weekend, smoothed out some dents behind the drivers door, and coated it in spray putty
This Mira is fairly rough, it is covered in carpark dents, and imprints from people leaning on the car. I'm just trying to get rid of the big ones, then i can paint it white again and ram it into motokhana cones biggrin.gif94B00CDF-orig.jpg81C5F7EF-orig.jpg
And then i did more fun stuff today. sports exhaust time! made a pretty simple mandrel bent 2 1/4 inch system for it. It's a litlle on the large side, but i had the mufflers and pipe laying around so it was very cheap(ie freeC75719F3-orig.jpg
https://www.sau.com.au/forums/topic/379694-project-dave/#findComment-6084940
well, just started it up, and it is very very......quiet, like surprisingly quiet, I had to remove the airbox just so it would have some induction noise.
I'm actually a little disappointed to be honest, I wanted it louder, Guess i might have to make some custom headers for it and a bigger front pipe.
Here's a vid of the first start up
http://www.facebook....v=2435666326031
https://www.sau.com.au/forums/topic/379694-project-dave/#findComment-6084941
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
