So lately my gear box has been feeling less smooth than usual and I occasionally grind a gear when the clutch is all the way in. I just got near gearbox oil put in (a good one) and still I don't think it feels as good as I want it to. I hear about people putting an additive to reduce friction and give smoother changes. I know there are negatives to using engine oil additives but what about gearbox oil additives? Has anybody used something similar? What did you think of it?
Here is the item I'm talking about http://www.supercheapauto.com.au/online-store/products/Nulon-G70-Gearbox-Differential-Treatment-125g.aspx?pid=1397#Description
Dylan.
https://www.sau.com.au/forums/topic/379742-gearbox-oil-additive/
People tend to have mixed results using these. There are also theories about the teflon additive glazing the synchros...not something you want to do as your gearbox will end up worse to drive than before. I'd be trying Redline Shockproof before putting one of these in...but it sounds like your gearbox needs some TLC AKA rebuild.
pretty sure i read somewhere that the secret ingredient in redline shockproof is also teflon..
I put 2 tubes of that nulon shit in my box with castrol mineral oil, it didnt make any difference in everyday driving at all...however after a bit of spirited driving once the box is well warmed up it is really nice to shift..so yeah i dunno :unsure:
Found it..
REDLINE SHOCKPROOF There are concerns about using REDLINE SHOCKPROOF type gear oils inside manual transmissions. While this is truly an excellent product, it has been found that the heavy Teflon-like particles are quickly centrifuged out of the oil and will build up inside the center diff housing and around the synchronizers and inside of the gearshafts. After several oil changes this build up may block oiling passages inside the gearshafts that lubricate the needle bearings and can reduce the overall effectiveness of the synchronizers, leading to poor shift quality. Also this oil is has too high of a viscosity for winter use. Therefore we do not suggest using SHOCKPROOF in the transmission unless the transmission is to be serviced often or a dog box.
most here using it seem to not have any worries though..probably cause most service regularly..I'm def gunna try it next time..
Found it..
The winter part use, is that for Australia or the US? As our winters differ to the US's, which is why they may experience those problems
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
