Anyone one here drives a Yellow S15 with a black bonnet is a SAU member and going up to the SAU Nats on here?
Just was a coincidence that he said hello to my gf at work today.
stealing your missus?
sooo where's your missus work again? :P
She works at a Pharmacy so if you need cheap drugs I can hook a brudda up.
dude, its all just like Fast n Furious style meets. when you are not around
Isn't this what SAU Boys and Girls look like?
