Sadly they are going even lower than that :'(
Series 2 120 k standard with only bov, $6500. Mate just picked it up last week. Soo cheap!
Had mine advertised for $7k got lowballed to $5k (prior to damage) so kept it instead hoping it will one day turn into a white s14a.
Good luck with your sale, seems is a hard market nowadays.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
