I've been to LA, Holywood, Beverley hills, downtown etc, didn't experience what you're crying about. Sounds like you've had a pretty sheltered life, or maybe you're just a pussy.
strangely enough i agree with you michael.
Fair enough. Could be inherited genes?
I better get life insurance then lol
haha yeah maybe :P
Its a noodle soup dish.
It's the shit.
Try it someday mang. Kinda like a spiced up turbo version of Pho.
it is
This is Pho:
This is Bun Bo Hue:
Note pictures may not appear as appetizing as in real life
man spiced up version of Pho, got to try it for sure
Jonoe is organise a Springvale SAU meet night, then you can have all the Bun Bo Hue you want.
Only eight dolla fifty. Cheap cheap.
Moh are you secretly running a terrorist cell? Secretly planting bombs in everybody's kitchen? Then one day.....BAM!
