Felt like a nerd going to midnight MW3 launch, but I was home with it by 12:10am, much better than shopping during the day. Only 29 people rocked up and two of them recognised me = friend fail.
Birds - Help me do fuel pump when I buy one? I see you have installed one in your car
NEVAR AGAIN
he says he won't do it even if he was paid..
This.
S14 a lot different to r33, well the way muskie explained it anyway.
I just want Birds to help me set the pump on the bracket properly, everything else seems fairly straight forward.
Can probably help you with that, but installing the pump on the bracket was the straight forward part. Just a few hose clamps and solder new terminals on the wiring.
The pictures in the OP of the DIY thread are correct with their position of the pump, ignore all the saps later saying they tried different lengths of hose etc.
It's expensive yeah?
A lil over $1,000 per subject and you need to do about 6. It's re-imbursed by your employer if you pass...
In Australia since yesterday..
Overall conclusion of L.A. in general.. there's some good areas but bad/poor areas outnumber the good suburbs.
Back already? Woulda thought you'd stay longer and go to other cities
