Not a fan of 99% of naked bikes, including that one.
Trying to talk myself out of going straight to a gixxer instead of going 250 -> 750..
Mrs is getting her license with s friend as well..
Thats what I did.. yet to be pulled over or caught. Only 3 months of Ls then you take it off so meh. I'm 70KGs twig and can handle it so you should be fine man.
Mines loud as and no fender on it as well.
If I do go down that road I'd obviously ride without the L or P plate...
What's the difference between L's and P's anyway? P's you're still restricted to 250 or bigger LAMS bikes and no passenger allowed on L or P's AFAIK, so what's the difference?
Ls for 3 months then nothing displayed (if your on car fulls which you are) but still restricted for 12 months but you get a full license sent out (blue tab at top) but on the back it says LAMS restricted with expirey date. so 15 months total restricted is minimum. During the 15 months no passengers either. (same lams restriction as well can get 250 or some restricted <650cc bikes)
I displayed Ls for the 3 months, was fine
Yeah gotta be black/or colored visor, none of this clear shit
It'll take me forever to settle on a lid design/color
Thats my helmet but with black visor, more go on what comfy first then look at diff styles
That visor must be tinted ASAP
The bike screen or the helmet visor? Bike screen has been replaced with a black one since, it looks awesome. Helmet visor, I might buy a black one but, clear is much better. Sun goes down and you're wearing a black visor = sucks a big one.
On P's you don't have to display a plate at all, unless you are on Ps for a car, and it's basically the beginning of your 1 year worth of practice until you can get a big bike.
Hmm, yours isn't a full on sports bike though is it? LIke your typical tough looking jap bikes, R1/R6, Gixxers, CBR's Ninjas etc?
An L plate would stand out like Flynn in a room full of attractive men, especially on an all black 750 gixxer, so I'd say not displaying them at all would be the go
I needed the black though because I wear glasses, sunny + clear =
Nah was talking about the helmet visor, already saw the photos you put up of the bike with the black screen, looks off its dick. And f**k functionality/safety, has to look good lol
Mines a "sport" not "supersport" bit more upright position than leaning way over, happy with that for now.
Same as this but full black no silver sticker:
A bit more learner friendly than a gsx R, but still got enough power to have good fun / sound.
Yeah wasn't bagging your choice of bike more the fact that a supersport is more likely to attract attention. Might be worth the risk, I'll see how comfortable I feel on the bikes at the license course and then maybe take my mates ninja 250 for a ride before deciding.
Would save money in the long run going straight to the 750, but not looking to die anytime soon either
Yeah I kno all good dude, just sit on a few bikes at the dealership first and remember that a ninja 250 is nothing like a 'real' ninja totally diff seating position / style of bike
I was in the same boat as you so settled for something in the middle. A bit cheaper too.
If I'm gonna settle for something in the middle I'd just go back to the 250 ninja and learn on that, upgrade to gixxer after 6-9 months
I've sat on my mates 250 Ninja, more upright position like yours than the real deal Ninja and other supersports..
There's a nice Ninja at my work every now and then, green which isn't my style but a tough looking bike..
I'm leaning towards an all black 2009 gixxer though, not a fan of the newer gixxers, something about the front just doesn't do it for me...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
