accessor called me and he basically said he prefers to write them off anyway due to not knowing internal damage / if they've been revving the shit out of it, I told him I preferred that anyway so hopefully get a payout rather than a fixed bike - I probably wouldn't feel 100% confident on it knowing it was fixed
Like? it's at the towing depot.. cant do much
and nah they havn't found the guys, doubt they will
Creative with a set of car keys...it'll probably be a write off though?
plastics cheaper than fairings though remember, but yeah hopefully might use the cash to get a ~100kw car tune and save for next new bike
Yeah man, cancel the rego straight away, they will refund the remainder. Maybe check if it's okay with insurance/police first but don't see what problem it could cause.
118kg f**k me, makes me want one lol. Looks pretty sick too, definitely buy.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
