yeh i had it reall bad last week. lost voice couldnt breathe to the point i was passing out. i copped it bad.
Augmentin duo forte 1000mg amoxylin still hasnt gotten rid of it.
It won't for the cold/flu part of it, antibiotics don't kill viruses. Two rounds of antibiotics haven't got rid of my sinus infection either :(
yeh man, and i love how everyone around you instantly becomes a doctor and says you should do this, you should do that and everyones opinion differs.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
