I agree completely.
I don't know how they thought the meet would turn out much different to what it did..
I feel sorry for the guy if he has to foot the bill, but you can't organize big meets in public places treating it as its private property, sure people payed parking but still..
nope. everyone was let out for free. so any chances the person who agreed for the car park to be provided, is now out of a job. (unless the physical owner - which I highly doubt under 'secure ePark')
lol let out for free?? The cops were down the bottom at the gate making sure everyone paid.
i was told majority got let out free.
this is a great picture.
when you see it...
http://www.flickr.com/photos/jkon_photography/7863192464/
sooo im not expecting any jdmst meets anytime soon...
Sam your not going anywhere. you're to much of a lazy prick to drive. lol
interstate registered, you are probably the least likely to cop a defect.
hows that fish taste?
um what?
Unaware of where the mask comes from
no only against any-one who has a business model that makes they a profit..as that means they are not in the majorities interest.
Martin can smell what I'm cookin
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
