Broke yours?
I need to fix and re-paint mine...
Not exactly broke but the car is so low that I scrape a lot and its worn off the whole lip underneath and is starting to get a little weak - it looks so nice at the height it's at but I guess that's what I get :/
You going to paint white man?
Yeah, it's annoying isn't it? The price you pay for being loooooooow
Yeah, going to repaint mine in same white, instructed not to paint it black.
I do wonder what $20k will buy me for my R... LOL
contemplating just selling now and getting a work car.
cbf anymore seriously just cbf.
should of bought an xr6t :P
why not just drive a merc around?
Edited by UNR33L
Yeah white lips look good - problem is those chips you get - carbon maybe? :P
Lol I know I have like 10K worth of things sitting in my rhdjapan basket just waiting for payment
No carbon cos with my bumper vents, black lip will look out of place. LOL'd at 10k things in rhd japan basket. I've got exhaust coming for it, suspension tops and maybe a set of coilovers and is in need of decent radiator, clutch and tune. That should do me fine for a while...
That's what I'm going to do, I cancelled the app because I bought the Evo, so I think I'm gonna go put the form in so I can have one for jan/feb latest
Work blows hardcore.
So slow no one can be ceebs being here. Plus all the birds are wearing those riendeer ears with bells on them. Constant jingling is doing my head in.
Go f**k one of them
About to head to work, should be fun entertain idiots who are too lazy to use their f**king eyes.
Hey baby you wanna help Santa cum only once this year.
Office broad minded persons will love it.
haha if they are anything like the wimmin at my work, termination of employment is worth it lol
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
