One thing that I don't understand that is they advertise like they need a worker urgently and when I contact them, they suddenly decide that they don't need one urgently. Happened to me 4 times today.
What's up with that?
They also legally have to advertise the position, even if they had someone in their own staff that was gonna get the position regardless.
Mum just told me of it.
Annoying really.
That's not all jobs, government it is but private not always
You sure? That's what I learned in my Diploma of Management. Lots of private companies could get away with it though because it's not like the government is aware they need someone new.
If this is the case, may as well write the job ad as 'I've hired someone and I'm forced to write this useless ad just cause the law told me so'
How can private business be told by government they must advertise positions.
It's not uncommon to advertise and especially publicly listed companies for high end jobs etc but I'd be very surprised if its law. I do know government have to advertise from memory.
Despite anti-discrmination policies, I'd say most companies of a decent size have that rule to stamp out favoritism, and to at least have some chance of ensuring they get the best candidates - not just a mate of a mate.
That being said, 90% of jobs are transacted on the private market.
Applying for jobs in seek etc is like taking a Hail Mary shot from the back of the court. I remember one job I applied for I was one of 250 applicants. 5 round interview process and got to final 2....then other person got it.
If you want a job, consider your experience, skills and interests - then start approaching companies that lend themselves to those criteria. Call front reception, ask to speak to the person responsible for hiring. It will be hit and miss but it's a much faster way to the decision maker than applying for any and every job on seek with a generic cover letter.
No dont get me wrong. I didn't say don't use seek - im just saying there are other ways - you new to approach it from as many different angles as possible, an your best chance of standing out from the masses of applicants is to chose more obscure paths of application.
Good luck with your search - stay motivated, keep a routine and try not to procrastinate!
While we're here, don't write generic cover letters...target them for the company. It should be the applicant version of the job classified; a reply to it. Quickest way to get a discard is if they pick up on language that sounds like you haven't even read the job description!
That or you forget to take out the company name of the last job you applied for.....had one of those cross my desk recently. Needless to say he did not get a call back.
lol, the lazy and clever ones do a mail merge with company name tags throughout the letter!!! Still looks suss as fk.
Also agree re: targeting companies specifically. Consultancy and agency companies who specialise in your field and outsource / account manage for other organisations are always happy to take a look at new candidates.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
