washed bike and car today, #productive #f**kinghashtag
Just got home from gym and thinking should give car a wash as well!
Its a bit too sunny almost haha, no shade u_u
Edited by kaitoukid
Okay, so this is the first thread i have started since joining the forum as soon as someone told me about the azn chicks thread.
It's not super busy like Skylines australia/boost cruising etc but the posters generally seem more intelligent, friendly and most awesomely the mods don't enforce ridiculously medieval rules regarding sharing of le boobies!
Still, I'm pretty sure i will be going out on a limb with this thread so before i go any further..
WARNING
Emo/Beta content WILL follow.
Now that that's out of the way lets get on with it, you see I am currently single and because of this dire situation have been forced to get on the interwebs to try and meet new ladies.
I signed up with a few of the more popular sites like RSVP, Oasis, Plenty of Fish and even Adult matchmaker for the lulz.
Since then its been a steady flurry of emails, photo exchanges and eventual dates, sometimes the contact would cost money (I dont want to know how many dorrars i have thrown away on 'stamps') but surprisingly a lot of the time it would be free (POF, oasis and person.com) and the only investment was a lot of time when mass emailing teh ladies.
I have met some shockers, some honeys and a whole shed load of absolute completely psycho hosebeast tree jumping swampdonkeys.
Theres been the usual highs and lows basically.
Finally i come to my point..Those lows.
I can usually shrug them off and get back on the wagon knowing that it will just take ONE more date for me to find the ONE.
Surely i can get knocked back or friend zoned AGAIN?!
wrong.
here's two messages i got today, one via facebook and one via text.
the text
" I'm sorry to say this, but I'm not sure if I'll be meeting you again; even though I do enjoy your company and our conversations, I'm not sure you're what I'm looking for.
I'm sorry if I haven't said it before, but I've only thought about it today.
Wish you the best, and good luck!"
like i said, normally, meh, next?
Two in one day though got me a bit rattled..
1. how do you guys cope with rejection?
2. any decent stories re online dating and if so share!
3. i really just want one of these..
what inspired me to finally be an OP
bless the lulz thread.
TL/DR
I keep getting knocked back by bitches and am foreveralone.jpg and a bit drunk.
here for free advice and/or hugs.
thanks guys, yeah Curtis i thought sophie wanted mah cawk.
guess i was smoking a big fat pipe of self delusion again, before this turns into a self pity thread though (too late?) i have another date lined up later in the week. This time a brasilian, this one is going to be into me FO' SURE!
lol, i've had a pet spider before, not the most charming of pets tbh.
and 2kg of seaweed salad, f**kEN AWESOME
I want seaweed salad :(
if there was pho involved, i would go to hallam
Yeah I'd go for pho too
wanna put a bike in upstairs sitting/tv area. waste of money or?
perhaps some good looking 250-600cc auction spec/track only/unregisterable cheapo doesn't even have to run
lee dez birds let me know if you wanna store yours at a safe warm environment for winter ^.^
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
