We've got a few staff changes, comings and goings... so just had finger food lunch in the sunshine with a few bottles of champagne... Think I'll avoid doing any work on Production Servers for the rest of the afternoon, just in case.
Always test on the production servers
Hipsterman, Gold Standard vanilla ice cream flavor. Get on it!
It's sad I'm replying to this name...
However yes, that's the one I used to have brah! I thought it tasted pretty terrible with water tbh, but amazing with milk!
so for lunch some mexican with margaritas...cos 10 hours later it means I get some privacy.
Sitting in the qantas International lounge now having a glass of Coldstreams hills Pinot noir with some papadams.
30 hours ahead of free booze and food for me..then couple hours sleep and stream bathurst..
your new.
don't leave till 15 min after expected to, well if you want to make a good opinion.
they will be less stressed about quality of work ATM more how enthusiastic you are.
show them you will put in an effort even it it means waiting till after knock off time on fri with no work.
basiclly we don't keep anyone on who bails early after 2 weeks.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
