lol you wanted varstoooeooeneoneoneonens which are fakes. lol
Hahaha
Besides, those are only 8.5" wide. I mean, where do you expect me to buy tyres for it? The wheelbarrow section at Bunnings?
maths is wrong
True, but blah blah has a point ;)
Hmmm I'm very interested but jsut wondering how the +30 will look on the front.
or you could get these like every other phaggot with a commodore
americantiredepot_dc66_22x9-1310-763-00-
Haha f**k that, I don't suck THAT much dick hahaha
isnt that like an extra 18mm of poke tho?
use this.
http://www.willtheyfit.com/
post results.
I see this rim on so many cars
Not sure why the owners think they look good
Same, looks like puss.
or of course the ultimate commodore rim:
LMFAO!! By far THE worst wheel in history. Would rather square wheels than them ugly things.
There was a dude on one of the commodore forums with them and not even a flamesuit could've stopped the guy from melting haha
use this.
post results.
http://www.willtheyfit.com/index.php?width=245&aspect=35&diameter=20&wheelwidth=8.5&offset=42&width2=275&aspect2=35&diameter2=19&wheelwidth2=9.5&offset2=30
COULD be a good fit, but the current fronts on mine sit pretty good with no scrubbage. Not sure if +30 is overkill for the fronts
brooooooo.
300300000Incubus-500-Paranormal-Black.jp
These rims SUCK! You're not helping at all mate!! :domokun: LOOOL
itll be a great fit, just run a tiny bit of stretch and some negative camber. do it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
