standard 33 GTR seat failure.
came into a left 270 and as I smashed it into 1st and ripped the handbrake the seatback let go and I ended up in the back
LOL!
that happened in a VL i was driving. didnt rip the handbrake, just turned a corner and planted it
the worst by far was that one when it BUCKETED down and that guy was there in the elfin clubman v8...
Poor dude had the worst day... freezing in the morning with no roof (he wore his helmet on the drive up) and then flooded on the way home (was using said helmet to pail water out whilst driving)
I was running 235 NT05's and driving at ~80 tops on the fwy as the car would just aquaplane into other lanes randomly...
yeah after sau nats in shep (the best one, when i finally met the one they call dezz, and jonoe and i realised that birds sleeps like hes dead)
driving back home with -6deg camber was sketchy as f**k.
had a mate who knows what hes doing when it comes to wiring come and help tuck the headlight wires, relocate the front body harness.
f**k me.
nissan really couldnt be f**ked with these cars..
that was the guy that was on R888 semi's and found out there was no drain plug in the car...apparently drilled one when he got home.
think i recall driving behind you and seeing your car all over the place
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
