No it doesn't. There are two sets of entries for non-Vspec, early and late.
For "Nissan" "Skyline" "1989/May - 1993/Aug ; R32 GTR (Eng: RB26DETT) (Early)" as the search options, shows sizes as 296x32 front and 292x18.
For Jul/93 - 1994 GTRs non V-spec it lists the same size as the V-specs. ie 324x30 and 300x22.
https://www.sau.com.au/forums/topic/380140-r32-gtr-brakes/#findComment-6063673
I think i should just measure up my existing discs to save any mix up whilst purchasing a set.
Cheers for the replies.
From 1989 to 1994 the R32 was fitted with Sumitomo callipers that used the 296*32 + 292*18 rotors.
The exception to this was the Vspec version that used the Brembo calliper & 324*30 + 300*22 rotors.
So the date listed in the DBA cattledog is wrong for the end of the smaller rotors on the GTR, ie it didnt end in Aug 93.
Look at the calliper & you will then point you in the right direction. The only way it would be wrong is in the extremely unlikely event that the previous owner has adapted the Sumitomo calliper to the 324 rotor in which case there will be an extra adaptor on the calliper.
https://www.sau.com.au/forums/topic/380140-r32-gtr-brakes/#findComment-6064854
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
