hey mate Im after a drivers seat belt, i need one for my 4 door but im going to find out of the 2 doors are the same. if they are the same how much for the seat belt freighted to adelaide suburb 5067
thanks
4 Door seatbelts are definately different. Thanks
  • Replies 91
hey mate how much for the engine cover and the brackets underneath that hold it down. and also a price on the A/C that you pictured. Thanks
Do you have the little white plastic lid from the fuel tank, the one with the fuel lines and fuel pump wires going through it? If you are willing to sell it please PM me a price.
Thanks
Justin
Sold so far:
Head unit
Clutch fan
Centre console plastics
Auto gearknob
Auto shifter surround
Ashtray
Weathershields
Windscreen Washer bottle
Wheels and tyres
Spare wheel
Jack and tool kit
Steering wheel and airbag
Front and rear seats
A pillar trims
Engine
Computer
Loom
how much drivers side mirror scew cover , the little triangle part on the door tops ?
how much for drivers seatbelt ? if its not frayed on the edges
and the red part off the seat frames on both seats where the seat belts click into ?
shipped to adelaide 5173
and floor mats ? if you still have them
Edited by Carbon 34
Hi mate,
We spoke briefly over text about the passengers door trim. How much are you after for it? Let me know cos I've been after one of these for a while. Also postage to 4214 on the Gold Coast, Queensland.
Cheers
Sold so far:
Head unit
Clutch fan
Auto gearknob
Ashtray
Weathershields
Wheels and tyres
Spare wheel
Jack and tool kit
A pillar trims
Engine
Computer
Loom
Floor mats
Drivers side front seatbelt
Rear hubs
Sold so far:
Head unit
Clutch fan
Auto gearknob
Ashtray
Weathershields
Wheels and tyres
Spare wheel
Jack and tool kit
A pillar trims
Engine
Computer
Loom
Floor mats
Rear hubs
Sideskirts
Rear speed sensors
Sold so far:
Head unit
Clutch fan
Auto gearknob
Ashtray
Weathershields
Wheels and tyres
Spare wheel
Jack and tool kit
A pillar trims
Engine
Computer
Loom
Floor mats
Rear hubs
Sideskirts
Rear speed sensors
Handbrake cables
Passenger door trim and switches
Sold so far:
Head unit
Clutch fan
Auto gearknob
Ashtray
Weathershields
Wheels and tyres
Spare wheel
Jack and tool kit
A pillar trims
Engine
Computer
Loom
Floor mats
Rear hubs
Sideskirts
Rear speed sensors
Handbrake cables
Front right hub/casting and suspension arms
Discs/calipers
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
