I scored a set of valve springs, but they are for RB26DETT.
Anyone used the valve springs from RB26 into a hydro RB25DET s1 head?
Its the HKS Step 2 ones.
RB26DETT 22001-AN001 For STEP2 BNR32, BCNR33, BNR34.
030910
I have got Tomei 270 8.8mm lift cams, in my rb25/30.
really would like to use these if i can.
any ideas?
cheers
So.. thanks for reminding me to call Paul, Mr Red R Racing comes through and answers a private number from overseas for once! was good to catch up...
So he mentioned that because these cams are not so big, it should be okay with stock springs, and that there will be no issues with the springs, but then he started being a detective and found some flaws with my setup and put me in the right direction!
car dropped a cyl once or twice, and once the engine even shut down... he said that I need to change the oil restrictor situation in the head, at the moment its setup as how sydneykid suggested in his thread but now for me I need to go back to twin 1.2mm feeds to give my lifters some more oil to stop them from bleeding and playing up.
also pointed out that the thick oil i am using aint going to help my situation either, i just switched to the lemans, so looks like its back to competition for me! (Motul)
Also, there is NO chance RB26DET springs will work in a Hydro rb25 vct liftered head. (for the searchers)
going to rip the head off and get this sorted asap!
cheers for all the input guys, im sorted
GT
he wont answer my phone calls or other guys who try to get there parts back from him .....you were lucky to get him :)
GT
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
