Ok so I finally got my R32 4door on the road after about eight months of it being "defected"
Gave it a service myself, oil, gearbox oil, coolant, brake fluid etc... before I took it out on the weekend for a run to see what it would be like.
So after about 200 ks of nanny driving, everything being fine and checking oil/coolant, I decided to give it a bit of hell. lol rb20de so not very fast just noisy....
seemed to be fine, ran well, didn't even move the temp gauge at all.
but now after checking the coolant it was pressurising and sending most of the coolant into the overflow bottle. also the idle became a but rough. So pretty much yeah the head gasket is most probably farked.
Anyway. was thinking replace the head gasket and get the head shaved to up compression and do some mild porting work on the head myself. also get some second hand gtr cams (correct me if im wrong but They just drop in yes?)
Im not looking for massive gains but just wanna see what i could get out my little 20 with just these things.
And a question about the tune, would it be a good idea to get a tune done or will the stock ecu just handle these mods?
Any Criticism or advice appreciated, as long as it isn't the usual... Get a turbo motor lol
https://www.sau.com.au/forums/topic/381209-good-idea-or-waste-of-money/
GTR cams dont drop in as they have solid lifters and you have hydraulic
Sure shave the head, dont touch the ports unless you know what you are doing or you will go backwards
all up, you will gain maybe 5hp from the slight increase in compression..
Save your money for the head work and get a Nistune board and a tune
Wouldn't waste my time with a 20DE to be honest, get the surfaces machined flat and put the head back on. Too much money wasted for no end result IMO. If you wanted an NA Nissan that performs well, you got the wrong car lol.
Edited by Super Drager
Are you sure the head gasket is the problem? ie. oil/water mixing and poor performance.
Issue could be something else and an easier/cheaper fix.
If you have to go to all the hassle and labour of changing the head gasket (I imagine you would maybe change the timing belt, tensioners and water pump while you are at it), it's better to just get a good RB25DE as a direct swap - they can be had for cheap or buy an RB25DEt if you have a bit more coin to spend.
i would check your AAC valve if the idle is rough as it is most likley gumed up with carbon. Its very simple to do just go to the DIY section in the forums and look for the thread to walk you through it. There are other threads on how to get the most out of your car just by tweaking and cleaning other things.
Yeah I like the idea of the 25de or 20det. But turns out it may have been just an air lock in the coolant up neer the bleed screw thingo, so got that out and hasn't done the pressurising thing just sitting in the driveway idling, will take it for a drive on sun to see if its all good. Bit off topic but what would you choose between a 20det or 25de. considering that i would rather an NA motor, but have driven a few 20det with the usual mods, Exhaust, FMIC, and VG30 turbo and i liked that but yeah id rather the NA but obviously not as powerful.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
