I am looking to fit out my r32 with some gear, keen to get top and lower front control arms, and rear control arms.
my question is, what fits R32 and what not?
I have a GTR rear end in mine, but i am using the GTS lower control arms on the rear.
Some sites say the R32 and S13 are the same on rear, some don't.
Some say the fronts are same also.
confused as hell, driftworks mensions 240sx etc etc
someone help me out here, can i just put the S13 lower front control arms on and z32 / r32 upper ones, then the S13 rear lower and uppers as well as traction rods??
and what about the tie rod ends? which ones can i use?
any info would be good.
cheers
https://www.sau.com.au/forums/topic/381309-r32-gtst/
I have a GTR rear end in the back of my 2WD gtst, I bent a lower control arm from the GTR rear end and replaced it with one from the gtst, they looked identical to me, I did not have any issue with tracking or wheel alignment out of the box. All the other pressed sheet metal parts look identical too & interchangable. My understanding that the only thing that is different other than 2 bolt subframe for the diff instead of gtst 4 bolt, drive shafts, and the important one is the GTR hubs are alloy instead of steel. This means that the have a different shock absorber design, GTR has a 'yoke?' on the end that bolts to the hub, where the gtst just has a hole for the bolt at the end of the shock absorber. Sorry for not being more technical with my description. But I think you will be fine swapping the parts you need.
  • Like 1
https://www.sau.com.au/forums/topic/381309-r32-gtst/#findComment-6081452
All the s13 arms fit the rear in the r32 except toe arms. With the Rear LCA (if you are going to swap it) check the width of the bush first as there are a few r32's out there running different sized bushes, mine was one of them...The taper on the ball joint is the same s13/r32.
On the front, s13, 14, 15, r33, r34gtst LCA's all fit, the later ones are a bit longer so you gain some camber. But you need to swap in your ball joint as the tapers are different in the later models, s13 taper is the same, but s13 arm is the same length as r32 so no gain. You need the r32 adjustable upper arm, but again be careful during install as i found that my 32gtst used a smaller diameter bolt at the outer end compared to the inner where as the arm i bought was set up for the larger bolt at both ends meaning i had the enlarge the hole in the upright and get 2 new bolts.
leave the factory tie rods and tie rod ends alone, no need to change them.
https://www.sau.com.au/forums/topic/381309-r32-gtst/#findComment-6081563
If i get stock S14 lower control arms for the front will it gain camber automatically because they are longer i have issues with the wheels fitting in gaurds i need to move them out a little bit?
If i buy the adjustable control arms from say driftworks or megan racing, should i get the S14 ones? or get the S13 ones? because they are both adjustable anyway??
you said also
"quote"
"On the front, s13, 14, 15, r33, r34gtst LCA's all fit,"
You did not mention R32 here, I have a R32 !! i want to put the adjustable lower arms on the R32 skyline but I only have options to buy for S13 and S14 from our supplier.
will the S13 and S14 FRONT LCA's fit on my R32 ?? and which one is the best to buy?
This
http://www.meganracing.com/product_detail.asp?prodid=807&catid=26
or
http://www.meganracing.com/product_detail.asp?prodid=815&catid=26
cheers
https://www.sau.com.au/forums/topic/381309-r32-gtst/#findComment-6084856
you said also
"quote"
This
http://www.meganraci...id=807&catid=26
or
http://www.meganraci...id=815&catid=26
cheers
If you are buying after market arms then in order of preference get r32gtst (if they are available) followed by S13 due to the taper on the ball joint being the same.
All of those front LCA's i listed fit r32's, hence why i said they all fit. I personally had stock s14 LCA's in mine but ran an r32 ball joint in them.
No offence Zeb, but i don't see anything particularly difficult about fitting up the arms in the thread you linked. Plus the megan racing arms remove the caster rod bolt issue. the sway bar should be sitting above the LCA anyway if the spacers on the outer end are fitted so no need to cut tabs off.
https://www.sau.com.au/forums/topic/381309-r32-gtst/#findComment-6086902
i ordered the Driftworks ones, and i asked them to supply them for the R32 GTST.
so lets see how it goes when i call them in the morning.
Parts on order are
Cusco rear upper control arms
diftworks rear lower
driftworks front upper
driftworks front lower
other stuff for car ordered or already here
carbon fibre bonnet
valve springs
drift hydo hand brake and master cyl
steering spacers
(looking for a set of coil overs)
and the reason why i want them is because i want to setup some sexy camber on the car, make it look like the goods when sliding at the F1 race track here in Abu Dhabi :)
thanks for your help guys. hope it works out
So next question is... what about the setup... for drifting.. how is the best setup going to be for traction in front and and rear (or lack of??)... im a NOOB drifter but would like that to change hence the work done on this car so far...
Everyone is different and i know you have to try different setups... but anything you guys have for me to read or from personal experiences id be happy to see!
https://www.sau.com.au/forums/topic/381309-r32-gtst/#findComment-6088136
a stock standard drift setup would be
Front:
Camber - 3 deg
Castor 7 deg
Toe out 1 -2 each side
Rear
Camber -0.5
Toe - 0
I run -0.5 total camber and toe in = 2 each side for max grip with 400hp and a long fast track
Front should stay relatively the same imo change your rear to adjust your grip levels
Also look at sway bars, some people run massive ones like me and some run none.. but mostly soft on front and stiff on rear
https://www.sau.com.au/forums/topic/381309-r32-gtst/#findComment-6088321
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
