  • Replies 886
Il post up a new thread with all the issues I had since the hypergear installation and what I did to fix them
Edit, il post it in here first and if there is a problem with what I say I can fix it before I create a reference thread.
Edited by lilcrash
Problems/issues installing a hypergear atr43ss-1 turbo.
1. Fouls on heat sheild on manifold - cut piece out to clear housing, dint the heat shield or use 10mm flange spacer.
2. Rear housing is 20mm longer - move all exhaust mounts forward 20mm
3. Water lines don't line up - get custom made lines
4. Oil drain on awkward angle - custom made oil drain
5. No boost reference nipple in turbo - weld on into one of your custom pipes
6. Needs custom intake - make custom intake
I doubt its the headgasket. Do a comp and leakdown test. U have been running 25psi. I would be a little concerned whether the tune was safe for that amount of boost. May be alright.
Clean all cooler pipes and catch can etc. Try running with catch can not connected to the turbo intake pipe. Run it into another can or bottle etc and monitor whther its still spewing out oil
I'm doing a comp test tonight, if it isn't head gasket i think it's deffinately rings. I clean up all I could reach, and have now swapped the intakes over until I can resolve this oil issue. I was steadily accelerating holding the throttle at 18/20psi when I started to smell the oil again. It only hit 25 psi 3/4times I don't feel it's safe at that level.
Ok turns out my engine is just rooted.
91,167,167,168,167,167. That was engine still hot, many burns on my fingers :(, poured oil into cyl 1 and it came up to 130psi. So yeah head gasket?
Air shouldn't be going past the piston rings..
You've Got some serious issues.
And when runnin that my boost, why the hell aren't you running a proper electronic boost controller?
Skimping on one of the most critical parts?
Can't be a head gasket if oil brought the compression up that much from 90psi.
I'd say that cylinder is about to grenade so I wouldn't even start the car anymore.
And if this is a standard engine, why the hell are you running 25psi of boost?
Seriously...
Are you getting paid to troll? Cause the more you reply you just add more and more f**kin
stupid comments...
First it was the tune, then the actuator, oil blowing out the ass end, headgasket...
Wats next? The chain slips on the sprocket? or it wont go into lo 4x4?
Take the f**kin thing to a mech and get them to solve it cause clearly you cant even let
alone describe your problems.
And the oil spraying could be because of the current problem could it not?
Boost issue still isn't completely resolved but clearly something has gone wrong somewhere. And as for the tune well that has absolutely nothing to do with me.
Yeah your oil problem could be as dramatic as it is because of Cyl 1.
Sounds like a cooked piston fr those symptoms (busted ring lands, crown) and that would let combustion pressure into the oil system.
Well there you have it. Get a 2nd hand motor and fix it. Consider taking it to a mechanic.
    • He obviously had his reason for flipping you off. I wonder what it was...
    • Thats why I stay far, far away from Eastwood. only go there if I wanna eat Korean food
    • I have to agree like, yesterday, I was driving down the warringah freeway towards the bridge when this jackass driving a beaten up Honda civic cut me off so suddenly it made me almost yank the wheel to avoid him hitting my car. Honestly and he had the NERVE to flip me off (or some other gesture Idk). Im a calm guy, but really some people just dont deserve to have a license, let alone be allowed to drive on densely populated roads/highways. If youre gonna cut through lanes at least use the damn turn signal
    • HPA do an interesting video on tuning, and Adrian shows on the dyno, moving from 10:1 to 12:1 (And I think even 13:1) and the power moves SFA. However, a couple of degrees of timing has a HUGE impact. Exhaust side of things will more be the length of the exhaust and how many bends and turns you have. The straighter you can keep it, the better. By a lot. Oh, and getting the diameter right. Bigger isn't always better. Going to big can actually lose you power.
    • I have to say, most people I see on the road fit the bill of atrocious drivers. Whether they be cowboys in their dual cabs, bogans in the Commodores, or the soccer mums. Pretty much most people on the road put zero freaking thought into driving. Barely look further up the road then the end of their bonnet, and have never even thought about how catastrophically wrong shit can go, by doing what they all deem as normal driving. Especially their late braking, racing to stopped lights, and sitting half a foot off the bumper of the car in front at 110km/h. Wanna know what's even better? By the time their kids get to be old enough to learn to drive, they've already got in the back of their brain what is normal driving, how annoyed you're allowed to get at people etc, and then their parents who actually have zero freaking skill at driving (Even though they constantly say "I've been driving for 20 years and never had an accident!") teach the little twerps how to drive, or should I say, how to make a car move. Literally watched a parent teach their L Plater, on a 4 lane freeway, that you just slam the brakes on, and push your way over, even with a B Double bearing down on you, and that's how you should drive, rather then, just keep going to the next exit. Same shit happens all the time for side streets etc, watching numpties pull dumb shit turns pushing across 3 lanes of traffic, rather than just go up the road another 30 seconds, and take the next turn that'll get you to the same location... Oh, and the damn right lane bandits. Or the retards driving along with their headphones in, and can't hear the ambulance or fire truck right up their ass about to run them over...   Pretty much, people drive on the road, like ego centric f**ks, and don't actually think how dumb shit their driving is, how it could easily kill them or someone else in a split second, or at the very least, how they're driving is contributing to all the shit they're bitching about on the road, like shitty congestion!
