  • Replies 886
Il post up a new thread with all the issues I had since the hypergear installation and what I did to fix them
Edit, il post it in here first and if there is a problem with what I say I can fix it before I create a reference thread.
Edited by lilcrash
Problems/issues installing a hypergear atr43ss-1 turbo.
1. Fouls on heat sheild on manifold - cut piece out to clear housing, dint the heat shield or use 10mm flange spacer.
2. Rear housing is 20mm longer - move all exhaust mounts forward 20mm
3. Water lines don't line up - get custom made lines
4. Oil drain on awkward angle - custom made oil drain
5. No boost reference nipple in turbo - weld on into one of your custom pipes
6. Needs custom intake - make custom intake
I doubt its the headgasket. Do a comp and leakdown test. U have been running 25psi. I would be a little concerned whether the tune was safe for that amount of boost. May be alright.
Clean all cooler pipes and catch can etc. Try running with catch can not connected to the turbo intake pipe. Run it into another can or bottle etc and monitor whther its still spewing out oil
I'm doing a comp test tonight, if it isn't head gasket i think it's deffinately rings. I clean up all I could reach, and have now swapped the intakes over until I can resolve this oil issue. I was steadily accelerating holding the throttle at 18/20psi when I started to smell the oil again. It only hit 25 psi 3/4times I don't feel it's safe at that level.
Ok turns out my engine is just rooted.
91,167,167,168,167,167. That was engine still hot, many burns on my fingers :(, poured oil into cyl 1 and it came up to 130psi. So yeah head gasket?
Air shouldn't be going past the piston rings..
You've Got some serious issues.
And when runnin that my boost, why the hell aren't you running a proper electronic boost controller?
Skimping on one of the most critical parts?
Can't be a head gasket if oil brought the compression up that much from 90psi.
I'd say that cylinder is about to grenade so I wouldn't even start the car anymore.
And if this is a standard engine, why the hell are you running 25psi of boost?
Seriously...
Are you getting paid to troll? Cause the more you reply you just add more and more f**kin
stupid comments...
First it was the tune, then the actuator, oil blowing out the ass end, headgasket...
Wats next? The chain slips on the sprocket? or it wont go into lo 4x4?
Take the f**kin thing to a mech and get them to solve it cause clearly you cant even let
alone describe your problems.
And the oil spraying could be because of the current problem could it not?
Boost issue still isn't completely resolved but clearly something has gone wrong somewhere. And as for the tune well that has absolutely nothing to do with me.
Yeah your oil problem could be as dramatic as it is because of Cyl 1.
Sounds like a cooked piston fr those symptoms (busted ring lands, crown) and that would let combustion pressure into the oil system.
Well there you have it. Get a 2nd hand motor and fix it. Consider taking it to a mechanic.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
