  • Replies 886
At a guess $500 at a minimum for shipping. So I could just assume $3500 aud to send it, have it done and send it back.
I didn't really want to pay that much but it's an option if I can't find anything closer.
Why fkn bother when a 200000km 15+year old RB25DET unopen engine can make over 300rwkw and last.. do what everyone else has said and buy a second hand engine replace the timing belt and water pump (100K service) and drop it in. you will have no problems making 240kw for years and most likely blow the turbo before the engine oh not to mention save alot of MONEY!
If you MUST rebuild so you know its like new i would recommend ERD (Elite Racing Developments)
$3500 nzd approx for rips to do it. Plus shipping both ways.
That isn't actually that bad. Most people pay that locally for some hack workshop to do it. Why don't you try ERD or all of the other local ones first?
Or why don't you just buy a neo off here? They come up for sale fairly often if you search every week.
jet r31 can you please pm me some contact details please.
il go to nissan about an oil pump and a set of pistons tomorrow.
il give spot on performance a call tommorow, thanks for the info booztjunkey
Don't buy anything unless you speak to a builder, they will have all their own preferred parts.
Why not just get RIPS to send over a RB30 short motor? Prep your existing head to suit, modify piping and get it engineered.
That is way out of his budget.
Edited by Rolls
Steven you should get a quote from CRD in Brisbane and Paul at Red-R Racing in Newcastle. Tell them to beat RIPS price and go with it.
I had Boostworx here in Adelaide rebuild my Stagea S1 Rb25 for $4200 including forged CP pistons, complete block prep and head clean up.
That was a Tow-in and drive out price, including the dynotune in a months time once Ive reached the 1000km running in mark. They outsourced machining but performed the complete assembly, including engine out/in.
The rebuilt forged bottom end is driving very nicely indeed; only minor issue I have is the fog lights & audio amplifier arnt working but I know they'll fix that up for me considering they were working pre-rebuild.
Once rebuilt find a Good workshop for tuning for a safe & mild tune and stick with them.
Personally Id be leaning towards a budget rebuild but including forged pistons over a used secondhand block, and I wouldnt be going for new genuine pistons when the CP's are cheap brand new on ebay currently. But thats just my opinion.
He needs a need AWD neo for a stagea and they don't come up every day.
NZD$4250 with adapter and pickup is way out of his budget?? Really??
ok there is lots of responses on here il try to do them in order.
r33 eddy - im avoiding using erd (had a great experience with him and a less satisfying experience), but they out source their machining as far as i know or atleast thats what i read on here.
wolverine - i did consider the rb30 and i talked to rips about it but just isnt what i am after. i want to try to keep my vct. if i could keep the vct i probably would have got one already.
rolls - il definately discuss my options with a machinist before purchasing anything.
tangles - crd is in silverwater nsw, im guessing you miss typed erd, as above not wanting to use them. i was looking at cp pistons because i assumed they would be a cheapish opton. im really only looking to do a refresh with new pistons/rings, oil pump and bearings anyway.
dvs - is it an awd block?
wolverine - as above is a good option just no vct opton so :(
Edited by lilcrash
If you use your neo VCT head prepped to suit an RB30 on the relatively low comp RIPS standard bottom end how will you lose VCT? The smaller chamber volume of the neo head will bump up the compression nicely and it will work just the way it does now except with more grunt down low.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
