Most exhaust shops will use 409.
But I would be inclined like yourself to use 304. I use these guys for all my ss tubing and bends. Very good quality products and the finish is perfect!
www.stirlingsaustralia.com.au/application/contact/queensland.html
Spewing your not in WA, otherwise I could supply the tube/bends for you no problem...No doubt at a much cheaper rate then the general public can get.
Edited by shaunus
Not sure what the big time fabricators here are getting their Argon for but BOC wanted $160 for the fill on an E size bottle and $13.90/month rental, just Called Star Gas and they deliver for free and charge $55 for an E size bottle and $12.50/month rental. Any other QLD peeps out there with good prices on stainless tube?
You need to check how much gas is actually in the bottle I'm paying $170 for 10.5m3 boc was only 8.4m3 and I pay $18 rent per month but if I get someone else to sign up I get free rental for a year I'm with supagas and I get free pickup delivery
I got Supergas down to $125 for the 10.5m3, you need to speak with the sales manager, you can't haggle over the counter.
Another gas wholesaler just offered me large bottles for $80 but I am yet to determine if I will be better off. The Supergas bottles have much higher pressure in them from my experience...
Hey bud I'm in w.a I'm after sone stainless tubing if u could msg me on 0497075260 cheers
Anyone know where I can get some 3mm thick flat acrylic sheet from? Prefer local in Perth, but will do online if it's cheaper. Masters and Bunnings have similar stuff, but they are very expensive.
Need it for composite tooling, so can also use polypropylene or similar. Just something that is plastic, relatively thin (2-4mm), and shapes easily using a heat gun.
  • 7 months later...
  • 3 weeks later...
  • 4 weeks later...
  • 9 months later...
does anyone have links and contacts for aluminium in Victoria, mainly for straight pipe/tube however full industrial retailers that do sheet, plate etc would be useful too
Edited by Dan_J
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
