So was rigging up a vacuum line to do the ol' skool steam cleaning of the engine....pulled off the boost controller hose that's connected to the bung on the std intercooler return pipe (connects to crossover pipe) and instead of it pulling air in at idle, it's pushing air out? So it's under pressure instead of under vacuum? How can that possibly be, shouldn't intake be under vacuum at idle?
https://www.sau.com.au/forums/topic/381478-rb25-on-boost-at-idle/
THIS
is what you are going to end up with
Really? what about WATER methanol injection... that does not cause this problem.. sure it might if heaps of water got in but a small mist couldn't hurt could it?
water meth is atomsied so it works, Have seen a conrod not 2 weeks ago that looked like the one above due to water in the cylinder.
Sucking water into your engine through a vac line is a new one, and also not the smartest idea in the world.
WMI operates at 150+psi and injects in the order of ML per minute a garden hose into a vacuum line does not operate the same way.
i think its mainly popular in the usa
i was a member of a usa subaru forum when i had my outback and a few ppl on there used to do it
ur supposed to use a thin clean line, warm the car up, raise the revs a little and dip the end of the clear line into some water and suck a little up, maybe 1-2cm's length on a 2-3mm hose
supposedly it'll vaporise a little on the way though the manifold and then turn to steam in the motor and clean the carbon out (subaru's apparently get a lot of shit in the heads/valves)
don't think i ever did it but yeah, just a little info for you guys
maybe i'll try it on my puss-bucket corolla :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
