Hey guys,
I just put on order a whole bunch of goodies for my 34:
Garrett GTX3076R
Z32 AFM
Bosch 040 Fuel pump
Return Flow FMIC
Soon to come
Nistune board
Insert suggested injectors here (Sard 600?)
Im going to do the install myself with the help of a mate and Im trying to find if anyone has done a 3076 low mount with the return flow intercooler, Just looking for some pics so I can get an idea of what I'll need to do as far as the piping goes. The car is a daily so Its probably going to be a bit of a mission to get it done but Im sure it'll be worth it.
Cheers
S
https://www.sau.com.au/forums/topic/381709-gtx3076r-on-r34gtt/
What size rear housing is the turbo? Internal or external gate? If your using the stock manifold, you'll need a 10mm steel spacer, to space the turbo of the manifold as it will foul.
Whats the car to be used for? Street driving?
Your power goal and the fuel it runs on will determine your injector sizes as a rough guide. At the power your making, you dont want to push the injector duty cycle past 80%.
Awesome info kitto it's a .82 housing internally gated I had heard about the spacer but wasn't sure. The dealer I bought it from is looking into that for me. I'm aiming at 320 kw in the future but not right away. main use is street driving occasionally spirited and I want to start doing some track days for a bit of fun
Ah ok, from what i have personally seen and been in. The .82 rear housing tends to be a bit laggy on an RB25. Especially if your not using an EBC.
However, the first RB25 was using a GT3076 not a GTX. This doesn't make a lot of difference at all, but just a slight amount. This engine was a non NEO engine aswell using BP98 making .347 Hub kW.
The second RB25 is a NEO engine, on E85, .63 rear housed GTX3076R making 368kW on the same hub dyno. Its Simon Michelmore's S14. He's had awesome results with the GTX3076R with a .63 rear housing
Both engines were also using steam pipe high mount manifolds which do make a difference.
Running lower boost pressure may cause the boost pressure to spike as the internal waste gate can't get rid of the large amounts of exhaust gas at lower boost levels.
It will do 320kW easily. What fuel are you going to use? E85 or BP98? This will choose your injector size.
NIStune - I like it!
i wouldnt count on making 320rwkw with an internal gate turbo on the stock manifold on 98. sure it happens, but most people fall well short. realistically you'll be limited to around 260-300rwkw depending on various factors. the standard manifold also makes the gtx3076 overkill compressor wise, better off with a standard gt3076.
as for injectors if you can find a set of nismos for sale at a decent price go for them. otherwise theres a few other bolt in options, plenty of info on here if you do a search.
as for bolting it onto the stock manifold, you'll need a 10mm spacer as said, along with longer studs, nuts and washers, custom dump, oil and water lines, cooler pipe mods and a custom intake pipe.
You actually need a 20mm spacer for the 3076's. The 3071's only need a 10mm spacer.
No you dont.
You need a 10mm spacer and extended studs.
I have a 3076 .82 on my RB25, with a Blttz Return flow. the turbine outlet pipe needs to be extended about 220mm.
Heres a pic of my stock pipes modded to suit. (top pipe, you can see the extension welded on.
If you trim about 40mm off the stock manifold heat shield you can get that to slot back on too.
And dont listen to anyone that says a .82 is laggy on an RB25. They dont know what they are talking about. You will love it to bits. Enjoy :)
Edited by gotRICE?
Im running the GTX3071 with .82 rear housing .60 front in second gear at 4000rpm the lil 25 really starts to boogey all the way up to 7500rpm i was worried bout the lag just like you were mate and i have no regrets bout the .82 its a great street setup its not hugely laggy but pulls like a freight train! :)
Still waiting to get some more info for you Lith but the head gasket leaked into number 5 on Friday while on the dyno. It will be another 4-5 weeks until I get it back on there. They were well into tuning by then so there could be some preliminary results to overlay with Mick_o's car when he gets back to the tuner.
Ill be running 98PULP, maybe avgas, shouldn't be too difficult for me to get. I will be getting an EBC (like the look of the AVC-R) down the track but might go with a boost tee or similar in the interim. Damn lack of funding!!
JonnoHR31, Is that a custom suction pipe or can you buy them or something similar?
Im actually not 100% sure lith but im pretty sure 21psi in 3rd gear is around 3500-3700 max and 4th gear is unknown mate my car is supposed to be hitting the rollers thursday so keep ya eyes peeled in my GTX3071 thread mate to check out my dyno sheet. Wolverine actually drove my car the other day and was of the opinion there was a little more to be had down low. So fingers crossed hes right
When do you get full boost in higher gears? I've been really interested in the difference in overall performance between a GTX3071R and a GT3076R :)
heres what i used for the piping mate :thumbsup: .'-
Suction line/air filter line
4'' - 3'' silicone reducer
3'' 90 degree elbow
3" 45 degree silicone bend
TURBO OUTLET LINE
A 2.5"-2" reduced silicone 90 degree bend
2 x 2.5" 45 degree bends
Thats pretty much all i used as well as a short piece of 1" pipe for my blow off valve plumback line and a piece of 3/4" for the rocker cover breather line :whistling:
Garrett GTX3076R
Z32 AFM
Bosch 040 Fuel pump
Return Flow FMIC
Soon to come
Nistune board
Cheers
S
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
