  • Replies 160
Posted Images
handheld pano while hanging out in a tree today. love this place, only a few minutes ride up the bikeway.
(click to zoom)
love the pelicans
(click to zoom)
and, while i was on the top of this...
i took this...
:P (click to zoom)
EDIT: Also love those shots Micheal
Edited by Jay019
Michael shots look great - some CC maybe set the white and blacks in either photoshop or lightroom to give the image the full tonal range. The images look great just lack that little extra punch!!! Only being super critical anyway
Valencia Spain
DSC_4858_59_60 by joshua.matthew.fitt, on Flickr
Prague Castle
DSC_0128 by joshua.matthew.fitt, on Flickr
love that first one Josh!
but any reason you used auto white balance in the bottom pic? would look awesome if wb was set properly (and horizon was 1/3 or 2/3 instead of in the middle)
Edited by Jay019
to tell the truth i have no idea about how to set the white balance correctly for a shot like that let alone at all. The castle shot was really hard as the lighting was from so many different sources and so many different colour temperatures :( Want to teach me haha
with night scenes tungsten seems to work best i found. on the D90 the white balance button is on the back (3rd from the top on the left, labelled WB/?/Key) just press it and give each setting a try. you'll eventually get a feel for which one works best in which light. i remember on the d90 you can set the white balance as a K value, that helps really dial it in, just give a few different settings a try. ken rockwell gives a good rundown on white balance. all i know about it is the camera tends to need a hand in artificial light. http://www.kenrockwell.com/tech/whitebalance.htm
EDIT: Nice Rhys, some sweet shutter dragging going on!
Edited by Jay019
Valencia Spain
Prague Castle
these shots=awesome
love the bottom one....
Some randoms from recent shoots:
So the girls wouldn't let the groom into the gurdwara unless he payed up. So after a few minutes of haggling a price (which the girls declined) he decided to get his credit card out. Priceless moment!!
Experimental shot using some strobes at the getting ready shots.
Trying a square crop:
Had a huge success from my first photobooth session :) Cant wait to do another one. Even a 3m wide roll wasnt wide enough for big group shots.
Will post up more soon. But the shot below is just showing my setup.
One of my corals:
Edited by siddr20
i grabbed a couple shots of the sky yesterday too. was awesome. i reckon we might get another one today. I remember it happend last year about the same time and happened for 2 or 3 days in a row.
love the variety and quality of this thread!
went for another ride to the onka river. looks like it will be a daily thing for me. actually got off the bike and walked out onto the swamp area for a few shots...
Nice capture there CPD.
Jay - Love the 1st and the last one. The simplicity and vibrancy is awesome.
Richie - Cheers man. Those are just randoms I have posted. Hopefully get the blog updated soon. Ah nice shots of the skylines there. I see you been trying that toy look type effect. eg) 6231 and others. Nicely done.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
