I aim for 7000rpm but sometimes I go close to the limiter (7500rpm) Peak power is ~6400rpm and peak torque is ~4200-4400rpm.
I'll be happy when I nail a sub 2.000 60ft. I'll get there eventually :D
Matt,
I might still pay to hold the gear if the power average is better as a result. Also the drop in rpm between gears sometime benifits from a slightly higher rpm if the overall average power can be maximised. Depends on how much the power curve falls away tho to.
Belive it or not Im running on 205/45/17 falken Azenis that have gone slightly too hard for track use. But are not too bad with a good burnout.
1.8 with 205s?? Not too bad with a burnout??? They're awesome! Do you have suspo mods?
What mods you got?
BOO57A
Nice times.
What was your launch technique.
I found with my stock clutch I could just dial up huge rpm, almost step off the clutch and it would just take off.
With the lightweight flywheel and heavy duty clutch, it just spins the wheels and axel tramps to hell and back.....
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
